Flush kit on the Ultra 150?
I am told the ultra already has some type of flush system set up but can anyone explain? should i install a flush kit? i have a kit for a zxi will that work?
I believe there is a plug on top of the exhaust pipe that can be opened up, and the hose can be put on.
It is not hard to do. i do not have mine right now, but it is easy to do. You will see it, just look.
Remember, turn the engine on, then turn the water on.
Turn the water off before turning the engine off.
This is correct, single black hose with a white nozzle fitting on the exhuast.
SK
what size is it? i may try to put a quick disconnect from my zxi on it, thats gonna be a pain unscrewing that knob off everytime i wantt o flush it..
- You may not post replies
- You may not edit your posts
Forum Rules
