Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
    Norman
    Re: SLT 780 wont run over 4000 rpm-Hitting limiter???
    What is the part number on your cdi? I think I have one for a 780 and a factory manual that I'd be willing to let both go cheap.
    Frequent Poster cjburt's Avatar
    Mar 2005
    Enterprise, MS
    Quote Originally Posted by fozziez28 View Post
    I will take a look tomorrow. Thanks... Do you think the cdi could cause it to only get 4,000rpms in the water? I just keep thinking it's a fuel delivery issue, but there again I can't get it right.
    Sent from my SAMSUNG-SM-G891A using Tapatalk
    Norman
    Easy way to determine if fuel is your problem is to remove the flame arrestor. Take the ski out move the seat back and remove and spray Chem tool in the carb when it acts up and see if it takes off. If it wraps out on the rpms like it should then it is a fuel issue. You can also check your fuel sets screws if they are not at factory spec.
