Page 12 of 12 FirstFirst ... 2101112
Results 111 to 118 of 118
Thread: VTS Bypass Fix
  1. #111
    Aug 2008
    Boise
    Re: VTS Bypass Fix
    Quote Originally Posted by estee View Post
    Thought I'd tell y'all what I did. I got a Suzuki outboard tilt trim relay, a little more pricey, at around 50 bucks on ebay, but very easy to wire and works like factory, trim stops and all. If anyone is interested, I can let you know how I wired it.
    if you can post the details that would be great.
    Jerr
    SeaDoo FAQs
    Kawi FAQs
    88 JS550
  2. #112
    Aug 2012
    whitby ont canada
    Re: VTS Bypass Fix
    I am interested too
  3. #113
    PWCToday Newbie Kirbster's Avatar
    Edmonton
    Re: VTS Bypass Fix
    I'm looking at the schematics for this fix and I don't see a ground anywhere in there. I have a 94 XP where the trim motor is located under the hood not in the rear. I'm wondering if this fix is going to work on my unit. My motor works great, the cable is OK, but while the vts module I have clicks, there is not enough juice getting through to move the motor. If anyone out there can offer up some suggestions, that would be awesome.
  4. #114
    PWCToday Newbie RAZEWORLD's Avatar
    Oct 2017
    New York
    Re: VTS Bypass Fix
    Just did it today....works great
  5. #115
    Jul 2018
    CA
    Re: VTS Bypass Fix
    Total newb here so please bare with me...after reading up I just want to be clear. The vts worked for about an hour on the water then quit. After going home and changing the rubber boot and letting the motor etc dry out I put it all back together and it appeared to work. Two subsequent times it would work for the first minute then quit again. Now it's not working at all and it shows 12v low when cranking even after installing new battery. I did check all fuses up front and they were all good...I have a 97 gsx and want to make sure this fix is for my ski? also the list that Koerbs? posted is showing the wires that I am supposed to connect correct? dont cut the brown as that is for the gauge? does this relay fit inside of the vts motor housing after being connected? Thanks for the help, Chris.
  6. #116
    Oct 2017
    New York
    Re: VTS Bypass Fix
    Your Gauge may not work after the fix...There will only be 2 wires that are hooked to your switch....Up...and Down.I put all my fix in a small tupperware dish and then filled with Silicone seal.It sat perfect on the top of VTS housing and was mounted..Works great.Sometimes if you don't keep track it may over extend before relay shuts down.Easy enough to put back on track.I set mine center before launch then tick which way i prefer.Have not made my gauge work as of yet as i keep my eyes on the water instead of the gauge.There is a fix for that as well.
  7. #117
    Jul 2018
    CA
    Re: VTS Bypass Fix
    Quote Originally Posted by RAZEWORLD View Post
    Great , thanks for the input.Chris.
  8. #118
    Oct 2017
    New York
    Re: VTS Bypass Fix
    You will also have same wires from black box to VTS unit....leave them as they have a fuse ....you can see the wire codes in the manual that is a free download from Seadoo.com. Mine is 96 XP 800.Black box meaning in the rear of the hull.
