    May 2009
    florida
    help with honda aquatrax f12
    my honda aquatrax f12 Fi warning light came on, changed the sparkplugs, used injector cleaner, run good gas always, Fi light still on. Don't know what to try next.
    Any suggestions??????
    thanks,
    davez
    Jan 2009
    Hawaii
    Re: help with honda aquatrax f12
    Try to get your hands on the service manual, it will help you a lot with the proper steps to troubleshoot your problem. Even if you have to buy the manual, it will certainly still be cheaper than throwing parts at it.
    May 2009
    florida
    thanks.
    Top Dog spatera's Avatar
    Jul 2006
    South Ga
    You need to pull the code to see whats wrong then clear it.
    03 Honda F12X (my favorite) Red of course
    Used to have:
    98 GP760, 97 GTX Sea Doo, 97 GP1200, 02 Honda F12X, 2-03 Honda F12X, 05 SeaDoo GTX Supercharged
    Need to have:
    F15X
    Top Dog
    Dec 2008
    Rock Hill, SC
    Search on here and you can find how to pull the codes. I cannot remember how exactly off the top of my head but looks easy.
    Jul 2006
    South Ga
    Check here. This should do it for you. If you don't fix the problem, you'll continue to get the same code after reset. At least you'll know if something is really wrong or just a freak alert.
    http://pwctoday.com/attachments/f18/...a-fi-codes.pdf
    Used to have:
    Need to have:
    F15X
    Feb 2008
    Burlington, N.C.
    Had the same code on mine last year. Mechanic said it was a bad knock sensor. he replaced it and it's been fine ever since. It was still under warranty so don't have a clue about the cost?
