Johnny's '95 PJS VHP 7000 Viper
Results 1 to 10 of 18
    PWCToday Guru johnny340's Avatar
    Dec 2007
    Wet Coast - Canada
    My Viper got the love last winter with a new paint job. Don from Kansas happened to have some new decals for it too! Prior to that, the engine got a brand new crank and a rebuild with new pistons, etc. It is basically stock which is the 70 HP 550 reed motor with dual 750 reed cages and Boyesen Reeds topped by dual Keihin 38's. I changed the stock Flame Arrester for dual K & N's that are mesh and run Outerwears to keep the water out.
    Some pics:
    Turfed the grab rail:
    Gotta have a sub pic:
    '98 Yamaha Superjet - Build Thread
    '95 PJS VHP 7000 Viper - Build Thread
    '92 Kawasaki 750 X2 - Build Thread
    PWCToday Guru jeffz0rz's Avatar
    Oct 2007
    san diego
    Re: Johnny's '95 PJS VHP 7000 Viper
    how rare is it to come across a PJS hull ? i really like the lines. is the tray the same size and the sx hull ?
    Dec 2007
    Wet Coast - Canada
    Quote Originally Posted by jeffz0rz View Post
    Pretty rare, I suppose. Only 500 of these ones made. It turns and holds a line really well. I think the tray is similar to that: 33 x 13 1/2"
    PWCToday Newbie melloman's Avatar
    May 2009
    el dorado hills
    I just picked up a 93' vhp 7000 this week looks goood but engine is toast, bent crank, scared the cases ect. I bought a t3 engine and am going to put it in but i'm worried about tuning and rideability it seems most people are saying the t3 isn't a good rec motor my previous ski was a roundnose sj. What impeller should I run?
    Sep 2005
    AZ
    Quote Originally Posted by melloman View Post
    It all depends if and how the motor is set up. If it is actually tuned to the pipe, you're going to need a big prop. My T-3 motor spins out a 17. I had impros repitch a couple props. The 20 degree seems to hook up pretty good. This is in a JS hull. The viper hull will be a lot worse since the boat weighs a lot more. Also, the PJS2500 pipe that these vipers come with doesn't work too good on a T-3 port...it is a little too long. You can run it but you're not going to get peak RPM out of it. I use a westcoast pipe with the cone cut down to just 2 rings. All my testing, this gave the highest peak RPM and top speed (obviously) under load.
    1989 Wet Jet - Upgraded 1994 50 HP motor & exhaust.
    Sep 2005
    AZ
    All Viper owners should look at a better hood latch. I got this one from mcmaster carr for about $20.
    May 2009
    Howell Michigan
    lol i have the f15 with the viper 7000 in it, what all u have done to yours?
    May 2009
    Howell Michigan
    oh T-3 nevermind i have the t1....
    Sep 2005
    AZ
    Not too sure what you guys are referring to with T1 vs T3. Really, these are just 550 motors. The only difference is in the radical T-3 exhaust porting is that the RPM range is extended up and you need to have an exhaust that matches it. Also, the t-3, once you get it tuned, will need a 440 pump to actualy run past 6,000 RPM. You can fiddle with a 550 pump - prop size, exit nozzel, ...but I never got a 550 pump to work and let the T-3 porting rev up to 9,000 RPM under load. The 440 pump allows this.
    May 2009
    el dorado hills
    my pump should be the 440 afterburner correct?
