Results 1 to 2 of 2
    PWCToday Guru p4pumpman's Avatar
    Jan 2006
    East tn
    fuel selector bypass?
    does anyone know what is the best way to bypass the selector valve ? im replacing all the fuel line in my hx due to that greenish-back tar substance thats in my lines . i took apart my selector valve to clean it and found that the big rubber seal inside is comming apart and im afraid it will contaminate my fuel system down the road if i leave it that way . i would rather bypass the valve and have a straight connection if possible .
    has anyone done this before?
    thats for your time , god bless
    The Show Me State - STL
    Re: fuel selector bypass?
    All you would need to do is run your reserve line straight to your carb. This way you will still be able to use the full capacity of your fuel tank. Other lines could basically be cut short and blocked off.
