    PWCToday Guru PJSC823's Avatar
    Aug 2007
    BILOXI,MS
    replating weber cylinders
    Who can replate the weber engine? The plating on the cylinders flaked off.
    Resident Guru 785 lugs's Avatar
    Feb 2005
    chicago il.
    Re: replating weber cylinders
    Quote Originally Posted by PJSC823 View Post
    Contact Randy at Watcon he can hook you up
    1 360 692 3492
    www.watcon.com
    Jun 2002
    Seattle WA
    It usually takes approx (10) days from the time I receive the block.I stock all engine replacement parts for this engine.
    Thanks,
    Randy
    Please visit www.weberpower.com
    PWCToday Newbie ripcuda's Avatar
    Jun 2011
    Spokane, WA
    Old thread... but I wanted to update it with recent information... in-case folks are searching.
    I've been working with Randy (user RJ above) at WeberPower (dot com) to fix one of my Weber blocks that has damaged Nikasil plating. Had him sleeve it for me.
    I thought this was good info for all prospective MSX 110/150 owners weighing-out their options with a damaged block. Randy said feel free to pass along the info.
    Sleeving:
    > more user friendly. no future plating flaking worries. re-honeable.
    > includes removing the original Nicasil, installing the new sleeves, boring to piston size & finish deck.
    >Approx price for 85mm (stock size) re-sleeve including sleeves - $655.00
    (includes WeberPower shipping block to/from machining source)
    Re-Plating Nikasil:
    > better for performance applications. better heat dispersal. less friction. harder surface.
    > requires new water pump bearings (both).
    > includes removing & installing new water pump bearings.
    > Approx price for 85mm (stock size) re-plate including bearings - $583.00
    Cheers!
