Results 1 to 10 of 12
    Apr 2009
    Northern VA
    Yamaha SUV 1200 Premix Conversion
    I have a 2000 Yamaha SUV that I want to convert to premix. I purchased a block off kit from SBT which just arrived. Any step by step directions out there? Advice / tips welcome. I have rebuilt car motors, carburetors etc... but limited experience working on skis.
    Re: Yamaha SUV 1200 Premix Conversion
    Unbolt pump,remove oil lines from carbs,disconnect the oil sending unit wires,remove hose clamp on oil fill hose,remove complete tank & everything at once.
    Install oil blockoff plate,join the two oil tank wires together (this will make the guage read full) blue/black wires. Mix your gas at 40 to 1 & your set.
    PWCToday.com Is My Home Away From Home ZMANN's Avatar
    Jan 2006
    AZ
    Yup 40 to 1 is safe! that pump can only do 50 to 1 wot and 50 to 1 is the approved premix rate but I run my 1200's and all my ski's and lawn equip at 40 to 1 without any fouling issues ( not saying that is ok for all ski's)
    you can also leave the oil tank if you want and pull the sender and ziptie the floats so they don't bottom out , this way it can be returned to stock if need be ps you will want to pull the throttle cable actuator also
    http://www.pwctoday.com/image.php?type=sigpic&userid=15348&dateline=1238301767
    Apr 2009
    Northern VA
    Thanks for the advice! Are either of you familiar with the SUV and what needs to be removed to make getting to the carbs and pump the easiest?
    The carbs are right in your face,pull on the lines they will come off,if you cant see the oil pump you are blind......
    Jan 2006
    AZ
    pull the carb cover and base to access the carbs and the oil pump is dead center in front of the engine
    Apr 2009
    Northern VA
    Thanks guys! Conversion is complete. I also capped off the open ports on the carbs where the old oil lines were attached.
    Dec 2010
    ME USA
    I all so have the block off kit.The primer too.I need help from ZMANN...Over the winter i have been leaking oil from the bottom of the SUV.
    Frequent Poster josephdstone's Avatar
    Sep 2010
    South MS
    I'm not trying to steal a thread, but I've been trying to find out whether or not leaving the pump, lines etc in tact would mess anything up.
    When I bought the 97GP last year the premix "conversion" was already done, except that the only thing that was done was....nothing really. The guy just started premixing and left the pump, lines throttle cable etc attached and lost the oil tank cap.
    Are there any potentially detrimental possibilities doing it this way?
    1997 Yamaha GP 1200 (760 hull)
    "Marines I see as two breeds, Rottweilers or Dobermans, because Marines come in two varieties, big and mean, or skinny and mean. They're aggressive on the attack and tenacious on defense. They've got really short hair and they always go for the throat."
    Rear Admiral J. Stark, U.S. Navy
    Jan 2006
    AZ
    well leaving the pump is basically lazy ,, no offense
    and oil in the hull is basically scary if it isn't a premix ski
    but pulling up a 2 year old thread
    guys feel free to start a new one
