Results 1 to 2 of 2
    Apr 2005
    Georgia(Lanier)
    JS550 motor diagram
    I am probably going to start rebuilding my 550 motor this weekend and I know nothing about it to say the least. I have all the tools necessary so it should be a fun project regardless. My question was, is there any online FSM i could access and/or motor diagram? If not, where would be a good place to pick up a FSM?
    Thanks ahead. . .
    1987 Kawasaki JS550
    2003 SeaPoo GTX 4Tec
    Sep 2005
    AZ
    Re: JS550 motor diagram
    Check eBay or order a manual from a Kawi dealer. I highly recommend getting an OEM one. It's the only place you find the detailed specs for crank clearance, sealant needs, right vs left hand threads....alll the quirky things you'd never think of. Clymer has a manaul too but I've always seen lots of errors or incomplete sections in those ones.
    1986 JS 550 - Engine build under way!
