Results 1 to 10 of 14
    Jan 2009
    NH
    Help fix my bent trailer tounge
    I just noticed my trailer's tounge has a slight bend to it. Any ideas on how I could straighten it back out? I tried banging it back into shape with a sledge hammer and even ran it over with my truck with no luck. Ideas?
    Mar 2007
    Is Everything!
    Re: Help fix my bent trailer tounge
    You're going to heed heat, and a whole lot of it. And once you're done your going to need to weld flat stock along the area of the trailer where you applied the heat and bent it back.
    Jan 2006
    Smoky Mountains TN
    This is hard to put in writing so look at my attached funny drawing. Hook trailer to car so tongue is held in place by the ball. Position trailer so bend in tongue is against an immovable object such as a steel pole or corner of your garage or building if it is concrete or brick. Go to back of trailer and push sideways so bend in tongue is pushed against the pole or building. If you push sideways on the back of the trailer the leverage will multiply the force put on the tongue where it contacts the pole or building.
    The hardest part will be finding a spot where you can fit the car and the trailer against a suitable pole or building. If you have no good spot around the house you may want to find a large empty parking lot with lots of sturdy light poles.
    Jan 2009
    NH
    Quote Originally Posted by dowkk View Post
    I tried using leverage when I ran my truck over it. I backed the truck so the tire was right over the bend. I then wrapped a chain around one end and hooked it to my engine lift and started to jack it up. I managed to lift the truck up off the ground, but the bend was still there.
    PWCToday.com Is My Home Away From Home afraz1er's Avatar
    Oct 2007
    BOISE
    whether you heat it up with an O/A torch or you bend it back your still going to want to be sure and weld some stock across the bend as POM stated. i would reccomend heat. or cut the old part off and weld a new tongue on
    - 03 Superjet - 1mm over bore, hooker 9/15, destroyer tubbies, carbon ride plate, cold fusion turn plate, quick steer mod, UMI bars, blowsion pole spring, jetmaniac girdled head, limited chamber b pipe
    - 94 WB1 - protec ride plate and top loader, 61x61x (FOR SALE)
    - 92 550sx - under construction
    - SNSJ - dual 44sbn, protec girdled head, 735cc, 62t61x, cylinder ported by tim tynan, protec exhaust, bored nozzle, 10/16, worx 201 top loader
    The Show Me State - STL
    How bad is it bent? I have pulled trailers with slightly bent tongues and it wasn't even noticeable. I would usually just recommend having it fixed properly instead of trying to bend it back. Bending takes strength away..so if you keep trying to rebend it, you are just weakening the metal...especially if heat is involved.
    I would find a small trailer repair shop and see what they would charge to fix it before I went and made things worse by doing it myself.
    Jan 2006
    Smoky Mountains TN
    Quote Originally Posted by tonyk72 View Post
    You need a bigger truck
    How did it get bent. Just do it again but from the opposite side this time.
    I dream skis gos's Avatar
    Gold Coast Australia.
    Replace it.
    formally known as seadookid PWCToday.com Is My Home Away From Home starter kill's Avatar
    Aug 2008
    knoxville tennessee
    do you have an actual picture? just drink a red bull...and bend it back with your hands. use elbow grease....sometimes that helps...you can get it here
    http://kalecoauto.com/index.php?main...products_id=32
    Quote Originally Posted by r_jacksontrucks View Post
    If u end up banging the room mates mom, call her her sons name.
    Quote Originally Posted by SJmullet View Post
    Never treat a women like a b*tch, and NEVER treat a b*tch like a women!
    i kill starters
    95 seadoo HX w/factory pipe
    98 yamaha superjet w/tons of goodies =)
    08 yamaha superjet stock roomate's ski
    90 yamaha superjet w/psi pipe loaner ski
    Resident Guru nojuice's Avatar
    Oct 2005
    mass
    Quote Originally Posted by seadookid84 View Post
    I checked out that site and will be buying a few of those items...especially the adjustable power band.http://kalecoauto.com/index.php?main...products_id=30
    <---Head stand on a 550.
