Octane mixing?
Thread: Octane mixing?
    Frequent Poster Thesepaperwings's Avatar
    SE Kansas
    Octane mixing?
    With 42cc domes, novis and factory pipes would the octane need to be raised? No porting and no spacers.
    Banned motoman96's Avatar
    Aug 2008
    Under a ROK....literally
    Re: Octane mixing?
    whats your compression?
    May 2008
    florida
    Re: Octane mixing?
    Running Sunoco 260? You could lower it.
    Can't read between the lines or read your mind
    from so far away.......y...................y.................. ...ay
    The mixing issue is, do you know what you want? from what
    you are useing? Going up or going down? Ethanol Eliminator?
    Are you loking for a blue mixture or orange/white?
    Methane or toluelene? Price you want to pay per PPM?
    Kawasaki Master Tech PWCToday Newbie
    Jan 2002
    Maryland..home of the Chesapeake Bay
    Re: Octane mixing?
    Quote Originally Posted by Thesepaperwings View Post
    Yes... To be safe you will need atleast 100 octane..
    Thanks, Steve
    Skiworx Watercraft Performance
    410-766-7900
    Ultra150.com Administrator/Owner
    Please Visit Skiworx.com
    email steve@skiworx.com
    Visit Ultra150.com
    May 2008
    florida
    Re: Octane mixing?
    If you know where you want to be octane wize, invest in a portable
    handheld meter, and you will know what you have, then raise by
    the hit and miss method with your booster, be it from napa, methane
    or (I use) Toluene. Thats how you get it, too much and BOOM!! Race
    fuels can be bought outright locally.
    SE Kansas
    Re: Octane mixing?
    I wasn't sure if I needed 100+ or not. Hmmm.....maybe I'll take the heads off and leave the rest, would I still need to mix?
    Jan 2002
    Re: Octane mixing?
    No! The problem with raising compression with pipes is that the pipes where intended (91 octane) to run around 125 PSI so anything higher will cause detonation without higher octane.
    Thanks, Steve
    410-766-7900
    Visit Ultra150.com
