Results 1 to 10 of 13
    Oct 2007
    Replublic Of Ireland
    GP1300R Catalytic Converter Problems
    2005 1300r with exhaust overheat warning and no power. 82 hours on clock. Removed exhaust to find the CAT Converter in 2 pieces (the frame and the honetcomb part). Cat was blocking the exhaust and the temp sensor is bent in half.
    Ordered OEM D-plate, fitted D-plate and a 1K resistor. Took the ski for a run today and the power is well down and it will not rev past 6000rpm. Compression is good on all 3 cylinders. Exhaut tone does not sound right.
    Starts first time every time. Will rev to max out of the water on the trailer.
    Anyone any ideas
    Couple of questions
    1. Is 1K resistor correct
    2. Could some of the broken cat be causing a blockage in the waterbox.
    All help appreciated
    Boris asked to be MU'd...literally PWCToday.com Is My Home Away From Home Boris's Avatar
    Sep 2003
    Floriduh
    Re: GP1300R Catalytic Converter Problems
    There could be a piece of that cat stuck down in your stinger or waterbox causing a blockage.
    Are the power valves cycling when you turn the ski off ? (or was the 05 the first year without those, can't remember now)
    Oct 2007
    Thanks for the reply
    Yes it is 2005 1300r PV.
    Will check for blockage in morning.
    Anyone have pics of a good cat to see how much of it is missing
    Oct 2007
    I removed the water lock and plastic water tank, all pipes etc back as far as the exhaust outlet. Found nothing, and there are no loose pieces rattling around in there. Any one got any other ideas as to what might be wrong. Thing i might check
    Apr 2003
    Charlotte, NC
    Try a set of new plugs first.
    Providing service to all model Ski's in the Charlotte, Lake Wylie area.
    Sep 2009
    Boothwyn PA
    Ok So I have a 2003 GP1300R with 97 hours as well and well I took it to the shop cause I got the overheating warning and a Check engine light on the screen. I also had a question for the screen as well. So lets start with first issue.
    I have go through the forum and have been seening that it is just cheaper to replace the Cat with the Cat Con/D plate and a new sensor. My question is how hard is this to do for yourself. I just ordered the parts for about a 115 bucks with shipping.
    Next question is: For the Screen it is crap it looks like crap and it is hard to see does anyone know what I can do to fix it or should I just invest in a replacement and is a replacement available?
    Your help would be Awesome!
    NPR
    You throw the screen in the garbage....
    Sep 2009
    Boothwyn PA
    HAHA thanks that is what I thought but will it have any issues and how hard is it to get off? I still like looking at how fast I am going haha so I wanna make sure that is not going to stop.
    NPR
    Lets just say it's not real easy,but not real hard with a little mechanical ability & the right tools.
    Sep 2009
    Boothwyn PA
    Ok awesome. now back to my orginal post any Ideas on that one as well? I mean I did work on 55 million dollar airplanes but we all know how different that is from a car or boat. I know I can turn a wrench. Think I will have issues?
