FS: Polaris stuff - Out of work sale!
Results 1 to 10 of 11
    Jun 2008
    Twin Cities, Mn.
    All items are brand new unless otherwise noted. Prices do not include shipping cost. Located in Minneapolis, Minnesota at 55121 zip code. Pictures available upon request...send PM or email at msf022@yahoo.com ...thanks!
    Part Number – Description – Quantity – Price per each
    5132202 – Impeller (7.0) - (1) - $75.00
    5132202 – Impros reconditioned impeller (7.0) modified – (1) - $75.00
    3021122 – 1200 stock heads (used) – (1 set of 3) - $30.00
    4170018 – Quick trim motor (complete) – (1) - $150.00
    5431765 – Trim nozzle – (1) - $10.00
    5130960 – Steering nozzle (used) – (1) - $10.00
    3240064 – Reed valves – (6) - $5.00
    2200733 – Carburetor needle valve kit – (3) - $10.00
    2200690 – Carburetor main mix screw kit – (2) - $10.00
    5431588 – Water housing pop-off valve – (2) - $1.50
    2200685 – Carburetor mid-range check valve kit – (3) - $10.00
    5810141 – Oil cap gasket – (4) - $0.75
    5430779 – Oil cap – (1) - $4.00
    5431360 – Fuel valve knob – (3) - $5.00
    3240191 – Cylinder head gasket – (6) - $15.00
    3240141 – Cylinder head gasket – (3) - $10.00
    2200731 – Carburetor idle stop screw kit – (1) - $5.00
    2200689 – Carburetor idle screw kit – (2) – $10.00
    3083349 – Piston rings standard – (6) - $15.00
    3083216 – Piston rod small end bearing – (2) - $15.00
    3140048 – Carburetor adjuster – (1) - $4.00
    2200672 – Pistons with rings only (standard size 81mm) – (2) - $35.00
    3240104 – Electric stator – (1) - $125.00
    1013943 – Virage I/Genesis I hood hinge – (1) - $10.00
    5433531 – SLT/SLTX purple wave back rub rail – (1) - $25.00
    5431392 – SLT/SLTX purple velvet rear grab bar – (1) - $25.00
    5521487 – SLH/SLX 99-01 models black side rub rails – (2) - $35.00
    XXXXX – SLH/SLX 99-01 OEM black mirrors (used) – (1 pair) - $40.00
    XXXXX - R&D intake grate (inhanced) (used) - (1) - $40.00
    XXXXX - Custom made extended ride plate for SL models (used) - (1) - $75.00
    Excellent condition used complete exhaust system “Log Pipe” less than 8 hrs. - $125.00
    Part #1261125 manifold w/bolts
    Part #1260991 sub #1261110 exhaust pipe
    Part #5411791 exhaust hose
    Part #5411792 exhaust hose
    Part #1260997 water box
    Came off of 1999 X-45 (SLTX-B)
    PWCToday Newbie TempoGT's Avatar
    Sep 2008
    Montreal QC
    Re: FS: Polaris stuff - Out of work sale!
    Check your email - about the Polaris R&D Intake.
    PWCToday Regular JOE96XP's Avatar
    Sep 2002
    FT. WORTH TX
    I got the rideplate and the grate.
    Jun 2008
    Twin Cities, Mn.
    Still plenty of parts left...just ask.
    Jun 2008
    Twin Cities, Mn.
    SLH/SLX rub rails sold...thanks Adam
    May 2009
    plainfield
    any parts for a 92 SL 650?
    Jun 2008
    Twin Cities, Mn.
    This is what's left as of: 7/26/09
    5431588 – Water housing pop-off valve – (1) - $1.50
    5431360 – Fuel valve knob – (2) - $5.00
    3240104 – Electric stator – (1) - $75.00
    Excellent condition used complete exhaust system “Log Pipe” less than 8 hrs. - $100.00
    May 2010
    Maryland
    DO YOU STILL HAVE "3240104 – Electric stator – (1) - $75.00"???
    PWCToday.com Is My Home Away From Home ZMANN's Avatar
    Jan 2006
    AZ
    this is almost a year old ,, you better pm him or check over at the greenhulk . net .. I hope He isn't out of work still ?
    http://www.pwctoday.com/image.php?type=sigpic&userid=15348&dateline=1238301767
    Sep 2010
    NJ
    Hi by chance do you still have the trim nozzle 5431765 ? Thanks
