My '92 Kawasaki 750 X-2 Winter transformation
Page 1 of 6 123 ... LastLast
Results 1 to 10 of 54
    PWCToday Guru johnny340's Avatar
    Dec 2007
    Wet Coast - Canada
    Below are a couple gorgeous 'before' shots before I did all of the following over the Winter: (pics and details to follow)
    Questions, Suggestions and Comments are welcome.
    Engine:
    750 Small Pin Engine (new top end)
    Cases modified for 650 Electrics
    Boyesen Carbon Reeds with R&D Stuffers
    Milled Head
    44mm Mikuni Carb with fresh rebuild
    Ocean Pro Flame Arrester with Outerwears cover
    New crank seals
    New Starter
    Matched & Polished intake manifold
    Matched exhaust manifold & head pipe
    Dual Cooling
    Coffman's Pipe
    Stock waterbox drilled
    Lightwieght aluminum waterbox mount
    Hull:
    2" cut off back
    Dakine Footstraps
    Hydroturf tray and rails
    Shortened Seat
    Relocated stern eye with SS reinforcement
    Hood exit internal opening relocated
    Bilge pump
    New through hull bearings
    Pump:
    Reworked ScatTrak 9-17 impeller
    New pump with dual cooling
    Westcoast intake grate
    Chopped ride plate
    Ground nozzle for max steering and trim throw
    Flipped trim nozzle with push/pull-rod actuated up trim
    Controls:
    Motorcycle trim lever
    Custom bike lever throttle
    Lanyard style face plate
    UMI Steering
    Answer Pro Taper bars
    Love that faded purple...
    Dec 2007
    Wet Coast - Canada
    Re: My '92 Kawasaki 750 X-2 Winter transformation
    Lever actuated trim mod:
    Motorcycle lever and cable hooked to custom aluminum actuator which pulls on a rod running through the factory 'return' cooling line to the flipped nozzle. All SS hardware and sealed on each end with rubber boots. Fully adjustable with super smooth operation.
    1/4" rod stepped down to stock threaded rod for travel adjustment at nozzle:
    Actuator:
    Shortened motorcycle lever:
    Cable running perfectly above intake manifold:
    Factory trim cable tube used to run dual cooling line:
    Nice up throw:
    Dec 2007
    Wet Coast - Canada
    Waterbox Mount:
    The factory rubber water box mount doubled as an anchor so I made an aluminum one and filled it with foam. This saved over 2 pounds and since it's at the extreme bow it should help. I drilled the waterbox with 6 1/2" holes through both baffles as well.
    Foamed, painted and ready to go in:
    Mock up of welded aluminum frame bolted to the waterbox. Luckily nobody will see these welds
    Can't see it anyway...
    Dec 2007
    Wet Coast - Canada
    Cut Seat and Stern Eye:
    With 2" shorter hull I had to shorten the seat and have it recovered if I wanted to retain the eye hole for tie down and towing.
    Stainless steel reinforcing on bottom side.
    PWCToday Guru Sea-Donkey's Avatar
    May 2006
    Madison, MS
    Looking good...
    2009 Honda Aquatrax F15
    1989 Wetbike
    Past PWC:
    3 x Wetbikes (1987, 1988, 1989), 1990 Jetstar, 2 x 2007 Honda Aquatrax F12 (1 red, 1 blue), 1992 Yamaha Superjet 650sx, 1997 Sea-Doo XP, 1997 Sea-Doo GTX, 2004 Sea-Doo 3D
    Frequent Poster kawashark's Avatar
    Sep 2007
    Fort Worth
    cool
    92 Kawasaki X2: 750 Big Pin, Hotrods Crank, ProX Pistons, Dual 40 Keihins, Coffman Exhaust, Prok Arrestors
    93 Kawasaki 750sx: Stock
    Dec 2007
    Wet Coast - Canada
    Hood Mod. Blocked stock opening that dumped water onto eBox and ran this tube which exits by the engine mounting plate just below carb level.
    Dec 2007
    Wet Coast - Canada
    Nozzle Throw:
    Flipped Nozzle:
    Dec 2007
    Wet Coast - Canada
    Trim unit after engine install:
    Trim Cable going between carb and cylinders:
    Dec 2007
    Wet Coast - Canada
    Dual Cooling:
    Second line through hull:
    Added some meat on the pump to tap into:
