Mach 6 X2 build - Page 3
Page 3 of 18 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 178
Thread: Mach 6 X2 build
    PWCToday Guru Kidd800Xp's Avatar
    Apr 2008
    Piedmont, Al
    Re: Mach 6 X2 build
    Did you build one with a 720 in it already.I thought I seen a post some where but I dont remember
    Re: Mach 6 X2 build
    Yes its the one in the avatar.
    Re: Mach 6 X2 build
    A goodie box arrived today with a pre- production hood from X2GUY,thanks X2GUY for shopping around on the shipping and for selling me this pre -production hood ,this is going to make my job a lot easier on making this plug.Guys if the work on this hood is an indication of what the final production piece is going to look like then you will be well pleased with his work,it looks awesome! I only trimmed the back section as I need a flange to do the vacuum bagging with on the new one piece hood.
    Re: Mach 6 X2 build
    The plan is to incorporate this into the plug for the hood mold,then when I am done with the plug ,I will cut it back out and finish it up for use on the Mach 5.
    Apr 2008
    Piedmont, Al
    Re: Mach 6 X2 build
    hopefully your making progress I might just have to slip down there one weekend this summer and see it.You decided on power yet ?
    Re: Mach 6 X2 build
    Quote Originally Posted by Kidd800Xp
    Probably sticking with the 720
    The Show Me State - STL
    Re: Mach 6 X2 build
    Cool build...the rotax motors put out some pretty good power..plus it doesn't weigh a ton. Should be interesting to see.
    PWCToday Regular yz250fpilot's Avatar
    Jul 2006
    huntsville, al.
    Re: Mach 6 X2 build
    Quote Originally Posted by WFO Speedracer
    Be innovative! Everyone's seen the 720 in an X2!!! .......787!
  9. #29
    PWCToday.com Is My Home Away From Home WB1994's Avatar
    Jun 2005
    New Hampshire
    Re: Mach 6 X2 build
    Interesting build , My question is , if your making a full one piece carbon fiber hood/steering section , why do you need the brace?
    Keep up the good work.
  10. #30
    Re: Mach 6 X2 build
    Quote Originally Posted by yz250fpilot
    There is no available exhaust that will allow fitting the 787 into the X2,I can fab up a lot of stuff but exhaust pipes are not one of those things I can just whip up.You are saying everyone has seen a 720 in an X2 ? You mean this one and only one of a kind I have here,they must have dropped by one day when I wasn't here then.
