B-pipe vs Limited vs Pro tec - Page 2
Results 11 to 20 of 26
    PWCToday.com Is My Home Away From Home FLWAVEBLASTER's Avatar
    Forest Lake, MN
    Re: B-pipe vs Limited vs Pro tec
    701 WaveBlaster Mod
    This system is for those who crave speed and go beyond the basic "bolt-on" engine mods. The Factory Pipe WaveBlaster Mod will deliver every horsepower lurking within your modified engine. Horsepower gains will vary depending on your specific engine modifications. The 701 Blaster Mod system uses a center bleed design stainless steel chamber, tuned exhaust manifold, and our exclusive tunable headpipe.
    $720.00
    InstructionsF.A.Q.sArticles701 WaveBlaster Mod701 WaveBlaster Mod
    1994 WB1 Speedwerx boat
    1997 GP1200 stage 1
    WWW.THEFLPROJECT.COM
    WWW.TCJETPILOTS.COM
    WWW.USEDBOATWORLD.NET
    PWCToday.com Is My Home Away From Home tfergusonracing's Avatar
    Nov 2005
    Right in the lumberyard, Danny...
    I don't know where "B-pipe" came from, but I believe that most people are referring to the mod pipe that is listed on their website when they say that.
    It takes a big man to admit when he's wrong. I am not a big man.
    Forest Lake, MN
    beat ya ferg
    1997 GP1200 stage 1
    WWW.TCJETPILOTS.COM
    PWCToday Guru jkirkland's Avatar
    May 2007
    Inverness Florida
    What do you guys think? Is factory pipe a big upgrade from a riva red. I have a factory mod pipe on my 750 sx and it rips. So far all I have read in this thread is that any pipe is good. Is it worth the $200 for the performance upgrade? I would like some more low end on my blaster but it runs good and dont want to waste any money if not neccessary. LMK what you think.
    2-750sx gps 54.1mph 1-95 blaster
    1-550sx 750conversion 1-95 F350 powerstroke lifted 4x4 dually, 1-95 nissan pu(pos), 1-02 lincoln ls w/20's, and 2 89 mustangs 1-327,1-408
    PWCToday.com Is My Home Away From Home Fox's Avatar
    Mar 2007
    Orlando, Flaw
    B pipe actually refers to the head pipe that goes from the exhaust manifold to the chamber. It is not yamaha specific, In fact the term B pipe refers to the part of the pipe that is universally interchangable between MOST of their pipes. The B pipe goes from a a kawi to a yama motor with no changes. It has the 3 water tuning screws to really let you fine tune the pipe. However B-pipe is the common name that is used to refer to the entire system
    As for comparison to riva red pipe to a b pipe... the FPP pipe will blow the bottom out of the riva red. Mids and tops will be similar, but the bottom end there will be no comparison, the riva wont touch it. I know this because Ive used them on my boat back to back.
    The superjet chambers are aluminum, the blaster chambers are stainless steel.
    Limited gives a bit more low end, and the mod chambers give more peak power.
    I have a blaster mod chamber if anyone wants it.
    Fox the Pirate. UWP IJSBA Flagman & Course Marshall
    Sailing :
    1988 sj550
    Warning:
    The above post contains pessimism and player hating to the highest degree.
    PWCToday Guru Wakerider26's Avatar
    Jun 2008
    Alabama
    I have been to Factory's website and read all that stuff a million times. It still says nothing about a "b-pipe"
    So I guess the slang term "b-pipe" comprises pretty much any Factory pipe made for a Yamaha?
    That is what has been confusing me the whole time. I thought the "b-pipe" was some magical hard to get limited edition bad *** black market super pipe, when apparently the whole time it is just a term that everybody uses to classify any Factory brand pipe for a Yamaha application.
    Please tell me if I am right or wrong.........I'm starting to get a kick out of this : )
    DVX 900RR
    XFS
    GPR
    Jun 2008
    Alabama
    Applause
    Finally!!!
    There is my answer! You the man Fox, thank you.
    DVX 900RR
    XFS
    GPR
    Nov 2005
    Quote Originally Posted by FLWAVEBLASTER
    beat ya ferg
    Aye.
    Nov 2005
    Quote Originally Posted by jkirkland
    I wouldn't spend the money.
    PWCToday Regular yz250fpilot's Avatar
    Jul 2006
    huntsville, al.
    Quote Originally Posted by Wakerider26
    Wrong, The b-pipe is a magical hard to get limited edition bad *** black market super pipe.
