General-X Build, 1100 Kawi in a X2 - Page 2
Page 2 of 35 FirstFirst 123412 ... LastLast
Results 11 to 20 of 348
    Top Dog waterdoglouie's Avatar
    Nov 2007
    South West Idaho
    Re: General-X Build, 1100 Kawi in a X2
    Quote Originally Posted by FlyinbySTi
    I am pretty excited to see this happen. I'll have to stop buy a few times while your working on it and try to give you a hand and not get in the way so I can learn a thing or two.
    This build is soooo cool that I may have to stop by and get in the way and Im like 2500 miles away!!!
    Aug 2008
    CT
    Ok well today I pulled the 750 out for my 95 and put the 2 on the bench next to each other. With everyone saying how big the 1100 is and how it is too heavy I just wanted to see how true that was.
    Well I gave the 1100 a fighting chance by leaving the air filters and starter on the 750. Both had the stock motor plates on them.
    So here it is
    750 = 80pounds
    1100 = 117pounds
    She is a big ***** I will say that.
    RAD DUDES
    www.RadDudesFI.com
    www.Jetskiporn.com
    Aug 2008
    CT
    Got a few more parts for the build. I have been alittle slow since I broke my arm last week.
    Got a coff purple pipe that seems to be right for the build but i will have to cut it up alittle.Looks like if I cut the tail cone off and bring it up and run a 180 off that ill be good.
    I also got a different aftermarket pipe but I dont think I am going to use much of that one.
    I also found the right coupler now, its off a 900 and fits the 1100 crank and the X2 shaft coupler size.
    RAD DUDES
    www.RadDudesFI.com
    www.Jetskiporn.com
    Frequent Poster Thesepaperwings's Avatar
    SE Kansas
    That's not much difference in hp per lbs. It should still hit super hard
    Quote Originally Posted by Twinturbostang
    So here it is
    750 = 80pounds
    1100 = 117pounds
    PWCToday.com Is My Home Away From Home Super Pro's Avatar
    Oct 2007
    Vancouver Washington , USA !
    You need a SXR 800 Skat magnum 12 vein pump for this to get the potential out of this 1100 motor set up other wise you will never see what it could really do , I have almost 40 lbs of led added to hold the nose down on my purple x2 with 77 rad stroker cranked 800 factory Kawasaki mod motor that runs over 60 mph , it is a 1987 x2 .
    1987 pro x2 western united states champion overall, 1991 california pro freestyle champion, 2006 region 3 sport class champion using an x2!! against the blaster an hx , Dan "Holditonhanson" the first and last of the old school pro x2 mohicans !!
    x2 mod 800 Stroker race !
    X2 Mod freestyle !
    Lamey 1200pluscc Mod Raider old school
    SXR stock spec race ski
    SXR 951 GP RACE SKI
    SXR 951 race ski testing video
    http://www.youtube.com/watch?v=XJTeN...eature=related
    Aug 2008
    CT
    I have a brand new sxr 800 pump with zero hours on it that is going in this build for now. Then down the road I can just drop the Skat mag pump right in and see how much it changes things.
    RAD DUDES
    www.RadDudesFI.com
    www.Jetskiporn.com
    Aug 2008
    CT
    Just ordered a bunch of stuff from John at Jetskihaven.com
    RAD DUDES
    www.RadDudesFI.com
    www.Jetskiporn.com
    Aug 2008
    CT
    Ok I have had a few other projects to work on, but I had some time the other day to work on my jig. I built this just to get an idea of how I want to make the motor plate. I lined up everything off a 750 to get everything as if it was in the x2, but i can see what i am working with on the bench.
    So I will be adding 2 extra mounts int he hull making 6 total. The stock plate has a bump in it the hits right where the center 2 mounts will be now. and the rear holes are off but the motor is only a hair off from being in the right spot front to back. The up and down is off by 1/8 inch or so to the stock X2 shaft.
    I am going to be using a JSH alum plate and welding extra on to it to make the plate i will use. I will have more pics soon.
    RAD DUDES
    www.RadDudesFI.com
    www.Jetskiporn.com
    I dream skis mrdx2pjs's Avatar
    Oct 2008
    tulsa,ok
    what type of pipe was you using on your 750 motor I noticed the large exhaust manifold I am looking for a head pipe for my coffman chamber for that type of manifold.
    Top Dog wadman's Avatar
    Sep 2004
    winsted ct
    lookin good. can't wait to see this thing go.
    840 x2, SXR 800 x2, 2 750 x2s, more than a few 650 x2s, a stand up or 2, your x2 might be next,
    Need a ROOF in CT? it's what i do. Best price and Service, Call and let me Prove it! http://eliteconstructionct.com
