    resident guru MILLER PHASE 3 1050's Avatar
    Oct 2006
    909/951 THE I.E. FOO
    Seadoo 947/951 C/b Oil
    OK SO I SEE THIS THREAD http://www.greenhulk.net/forums/showthread.php?t=60102
    AND IT SAYS TO PUT 1.35 OZ OF FLUID IN THERE ...SOMEBODY SAYS PUT IN 30WT OIL OR TO PUT IN SYNTHETIC JET PUMP OIL ...WHICH IS RIGHT ?I KNOW THE JET PUMP OIL IS 75-90 WT OIL( WELL ATLEAST THAT WHAT THE AMSOIL SYNTHETIC BOTTLE SAYS 75-90 SERVER GEAR OIL)...SO WHICH IS THE RIGHT ONE TO USE ?THANKS FOR YOUR INPUT JOSH
    Re: Seadoo 947/951 C/b Oil
    Any low weight motor oil will work fine.
    Oct 2006
    for some reason 30wt sticks in my head ...there is a big difference between 30wt and 75-90...i wish i knew which was the correct one
    Feb 2002
    Vancouver, BC Canada
    The manual says 30w.
    Chester
    Stand up:
    98 SXi-Pro
    Couches:
    96 XP
    86 X2
    Oct 2006
    ok 30wt it is thanks guys
