JETMATE owners thread ... - Page 247
Page 247 of 247 FirstFirst ... 147197237245246247
Results 2,461 to 2,469 of 2469
  1. #2461
    Frequent Poster stonehenge's Avatar
    Mar 2004
    San Dimas
    Re: JETMATE owners thread ...
    Quote Originally Posted by Boz Mon View Post
    Got this app buttoned up tonight. Got the westcoast pipe to fit and a 3/8 water line out the stock pisser
    Amazing!
    Love it!
    Where did you find that hose (from cone to water box)???
    And is there a line going into the back of the chamber on the pipe, if so how did you plum it?
    thx for sharing pic and process!!!
    "They say I obstructed an investigation into something that didn't happen? And they want to impeach me for that?" MAGA 2020
  2. #2462
    Mar 2004
    San Dimas
    ....and does the pipe hit the motor cover anywhere?
  3. #2463
    Top Dog Boz Mon's Avatar
    Jun 2005
    Kankakee River
    I ordered the hose online. A place called Pegasus racing or something like that. The pipe does not hit the doghouse at all. And the line going into the back of the pipe is the stock location water line on the west coast pipe.
    I will say, I had to cut a tiny bit off the chamber for it to clear in the front. I think I could have gotten away with cutting less than a full ring.
    Also, there is a vent under the pipe. I had to pull the rubber trim piece off.
    1994 FX1
    1985 JS550/650 conversion
    2015 Fiat 500 Abarth
  4. #2464
    Mar 2004
    San Dimas
    How does she run now on the PIPE!?!
  5. #2465
    Jun 2005
    Kankakee River
    I havenít done a water test yet. Iím just getting this thing together. I need to wire the bilge and fan and a few more small things. I hope to do a water test this weekend.
    1994 FX1
  6. #2466
    PWCToday Newbie dollafiddy's Avatar
    fort worth
    I just got a 89 jetmate that needed some work. I put a 38 keihin cdk2 on it and I can’t get the fuel pump to work right. It will pump like it should at for a few seconds the it stops. I blew into the pulse line and it is stopped up. I pulled the carb off many times and it seems to fill up and won’t pump anymore. It fill fire right up with some fuel poured down the carb. I’ve tried other pumps from a dual carb setup and it does the same. What is causing this?
    Side note: looking for the red throttle trigger and a few other things.
  7. #2467
    Jun 2005
    Kankakee River
    Quote Originally Posted by dollafiddy View Post
    I just got a 89 jetmate that needed some work. I put a 38 keihin cdk2 on it and I canít get the fuel pump to work right. It will pump like it should at for a few seconds the it stops. I blew into the pulse line and it is stopped up. I pulled the carb off many times and it seems to fill up and wonít pump anymore. It fill fire right up with some fuel poured down the carb. Iíve tried other pumps from a dual carb setup and it does the same. What is causing this?
    If it was me, I would throw that keihin right in the garbage and swap an sbn44. Iíve never had any luck with the keihins. My best advice is take it all apart and give it a good cleaning once more. Maybe thereís something stuck somewhere.
    I figured out why my motor was running like poo. I was only running on 1 cylinder. Sent my coil to jet ski solutions today in hopes to have it back for the weekend.
    1994 FX1
  8. #2468
    PWCToday Newbie Rossvegas's Avatar
    Jun 2017
    Rowlett
  9. #2469
    Mar 2004
    San Dimas
