Page 209 of 209 FirstFirst ... 109159199207208209
Results 2,081 to 2,086 of 2086
  1. #2081
    PWCToday Guru subhard's Avatar
    Feb 2011
    anchorage ak
    JETMATE owners thread ...
    Anybody know what rubber fits in the rub rail? https://www.westmarine.com/rub-rail
  2. #2082
    May 2007
    Re: JETMATE owners thread ...
    Sub ue link didn't work for me.
  3. #2083
    Feb 2011
    anchorage ak
    Quote Originally Posted by subhard View Post
    more digging revealed this kawasaki part number, anybody know if dropping one of these buttons in would work
    kawasaki 27010-3732
    https://s3-us-west-2.amazonaws.com/l...0-3732+(1).jpg
    So update on start/stop buttons. Any Kawasaki button will and can fix/replace a broken jetmate one. We bought an old used start stop assembly off a sit down kawi off eBay, tore it apart, and basically just had to re-bend the bracket inside the joystick to fit a new button underneath our broken stop. The wire colors don't even have to match. It's literally just a button that makes a connection to tell the thing to stop. The entire project took 30 minutes. If you have a broken start or stop go nuts. You can't screw it up.
  4. #2084
    Sep 2015
    Phoenix, AZ
    I'm finally able to get my jetmate project started (wound up picking two of them up almost two years ago) and have a couple of questions. I'm going to have most if not all the work done at a shop.
    More than likely I'm going to need the engine rebuilt. Should I just stick with the stock 650, have it rebuilt into a 750, or spring for a groupk "sleeper" kit?
    Is there an easy way to visually tell the difference between a 650 and an upgraded engine?
    Are there any shops you would recommend in the Phoenix/Lake Havasu/Parker area for doing this type of work?
    Thanks in advance for any help.
  5. #2085
    Frequent Poster Scurve's Avatar
    May 2012
    Albany
    Quote Originally Posted by azdesertrat View Post
    I'm finally able to get my jetmate project started (wound up picking two of them up almost two years ago) and have a couple of questions. I'm going to have most if not all the work done at a shop...
    If going with a shop to do the work, you are kind of stuck with a 650. Unless the shop is experienced with doing fairly involved custom projects.
    You basically pushing a brick through water with a Jetmate, getting more performance out of them is a practice in diminishing returns.
    If you want to keep things at least looking stock and using a shop, GroupK kit would be a good way to go if they are ok with you providing your own parts.
    If money is no object and you want a monster Jetmate, look at some of the other projects on the forum to get an idea. People have some really amazing set-ups, but have basically re-built an entirely new ski that just happens to include a Jetmate in the process.
    X2 Hood Vents (3D Printed Nylon $$$) - http://www.shapeways.com/shops/Scurve
    X2 Hood Vents (ABS Plastic $$) - http://www.ebay.com/itm/Kawasaki-x2-...JX4gS4&vxp=mtr
    X2 Hood Vents (Plastic Resin $) - https://www.etsy.com/shop/ScurveX2
  6. #2086
    resident guru ang4th's Avatar
    Aug 2003
    Hamilton,ontario
    simply look for and buy a "doner ski" like a 750ss they can ve found cheap and with good engines in them ,, if you are not confident to do the work yourself have a shop swap out the engine and electronics into the jetmate .. the 5 blade props in some of the heavier 750 sit down skis can also be made to fit a 650 jetmate pump ..
    "It is better to keep your mouth shut and appear stupid than to open it and remove all doubt."
    Hamilton Ontario Canada . need old school Kawasaki 650 , 750 or some basic superjet parts and you are within Canada ? message me I may have parts available
