JETMATE owners thread ...
Page 1 of 240 1231151101 ... LastLast
Results 1 to 10 of 2391
    Resident Guru ang4th's Avatar
    Aug 2003
    Hamilton,ontario
    we could start by posting a few pics of our own jetmates and could also post lincs to other jetmate specific threads here ,,,
    here is mine .. dropped a 750 into and SS impeller .. some cavitaion issues but not too bad now .. if you load it down too heavy you have to turn while getting up on plane to get it on plane ( with 4 on board ) with one or two on board no real caviation issues .. kids love the little boat .. so do I
    bought a second one .. its for sale ..
    "It is better to keep your mouth shut and appear stupid than to open it and remove all doubt."
    Hamilton Ontario Canada . need old school Kawasaki 650 , 750 or some basic superjet parts and you are within Canada ? message me I may have parts available
    Nov 2007
    central Texas
    Re: JETMATE owners thread ...
    No pics of mine yet...
    SBT rebuilt 650, 28 mm pull-down carb, feeding it pre-mix 40:1.
    Seats reupholstered white with blue trim. Stuck an ancient trolling motor on the nose. hooked up lights and installed a fish finder...
    Its now a mini fishing boat.
    Its only rated for 3 people... 4 is unsafe by definition.
    I'll have to try the turning to get on plane trick though... with a second heavier guy in back all mine was doing was raising the nose higher and higher. I figured it was time to let off the throttle when water started comming in over the back.
    Sold it
    new york
    I would like to see the pictures i am setting mine up to fish with rodholders ,fishfinder,gps and i am going to make a flat platform to fit the rear seat area as a fishing platform.this boat is going to be great for flats fishing!
    GERFF
    Guest
    here is mine.
    Aug 2003
    Hamilton,ontario
    here is the one I just bought .. I will be selling now or in the spring with a 650 with fresh top end .. seats were recoevered just before prev owner discovered rainwater filled up the engine .. that has to be the biggest flaw in these boats .. they look like a bath tub .. and act like one .. they realy need a better drain plug the damn water is halfway up the engine with the one they have designed ( if on the trailer and unpluged, and not clogged )
    Nov 2007
    central Texas
    Quote Originally Posted by ang4th
    First line of defence from them filling up is to add a float switch which can turn on the bilge pump even if the master switch is off. Then check the battery charge regularly. (because that pump might pull the battery down if you ignore it all winter)
    The bilge pump leaves about 1/4 inch of water in there... so store it nose high and allow for good airflow to let it dry if you don't want to be going out with a shop-vac after every rain. (even if it has a tarp over it...) Nose high also tends to flow the water back to the deck level drains
    If the seal between the doghouse over the engine and the deck is good, then most of the water should drain out the gravity drain. (if the correct deck drain plug is open and the transom plug is out) But these are so old now that most will need the weatherstripping replaced by now. I just ordered some from JC Witney. If it is the right stuff (hard to tell without actually seeing it...) then I'll post the catalog number. 13 ft for $27 including shipping. One kit shold do the doghouse with maybe enough left over for the engine hatch.
    Sold it
    Resident Guru Sarge707's Avatar
    Jan 2006
    Southington, CT
    They look Great for a young family or Fishing and you probably can,t beat the fuel cost!
    "The Hull Makes the Difference"
    89SP, 91XP, 93XP, 93WBlaster 94XP, 95HX, 95XP-L, 96GSX, 97XP, 98XP-L, 2002GTX, 2003 GTX-SC, 2008 RXT-X Superski , 09 Spyder Can Am Roadster.The End!
    PWCToday Newbie ahavnaer's Avatar
    Jul 2007
    Tega Cay, SC (Lake Wylie)
    how big is the engine compartment, has anyone converted to a larger displacement engine with more horsepower.
    Nov 2007
    central Texas
    Quote Originally Posted by ahavnaer
    There's LOTS of room in there...
    Maybe 4 inches more height.
    Eliminate the oil injection tank and the bracket its mounted in and do a little glasswork to extend the bilgewell forward and you could alnost stick two 650's in in tandem...
    Width is an issue due to the exhaust...
    There have been reports of 750's being dropped in with essentially no modification.
    The way mine performs... the first place to go to improve it is most likely the impeller. Maybe the entire pump should be upgraded.
    75% throttle it gets up on plane.
    60% throttle will hold it on plane.
    Going past 80% doesn't do enything except make the engine spin faster.. the boat actually slows down if I go above 90%. (positive indication of cavitation)
    Sold it
    Resident Guru tweeker's Avatar
    Apr 2003
    Denver N.C
    The 750 upgrade is more than enough power with the correct pitch like a 14/19 solas and u got a rippin jetmate
    1987 wetbike silverstreak
    1987 Yamaha exciter 570
    1988 wetbike silverstreak
    1989 x2 750 superstock
    1991 SC Piped 750
    1994 Kawasaki SC piped 750
    1996 Yamaha Vmaxx 600
    2005 SXR stock
    2006 SXR1100
    2006 grizzly 660
    2015 fzr sorta stock
    2015 FX SHO
    2016 FZR sorta stock
