Page 1 of 3 123 LastLast
Results 1 to 10 of 23
    Top Dog
    Nov 2006
    Twin Lakes ID
    Nice looking $20 tachometer from Harbor Freight...
    Like many others here I have been looking for a way to add a tach to my 96XP. This may be a really inexpensive solution.
    Harbor Freight has started carrying a nice looking series of two inch gauges for $20 each. One is a tachometer that goes to 8000 RPM, perfect for mid-90's Rotax engines. Its pickup connects to the low voltage side of the ignition coil. If you switch it for 4-cylinder operation I believe it will read accurately for 2-stroke Rotaxes.
    Here's a link to the webpage:
    http://www.harborfreight.com/cpi/cta...emnumber=98480
    My 96XP has a roughly two-inch circle on the fiberglass in front of the seat that could be cut out to accommodate such a gauge. I don't know what's behind it, or how much depth is available (the gauge requires 2-3 inches).
    I haven't personally seen one of these gauges yet, but thought I'd share the idea.
    1996 XP (787 engine)
    1997 GSX (787 engine)
    Mostly factory stock
    Feb 2004
    Glendora, California
    Re: Nice looking $20 tachometer from Harbor Freight...
    That "circle" in your dash is where Sea Doo put the info guage on the 1995 XP 800.
    Feb 2004
    That volt meter might stop about 2 million questions here about voltage regulators/rectifiers.
    What would be handy is a single wire inductive tach and a voltmeter mounted on a portable holder to attach to pwc's to do quick diagnostics at home in the garage.......
    Top Dog
    Nov 2006
    Twin Lakes ID
    Then hopefully there is enough depth there to hold a gauge in the 96 model! I can't remember offhand but will check next time I'm at the lake.
    Top Dog Landworks's Avatar
    Mar 2007
    MA
    I'd like to hook up a temp guage.
    3 96 XP's
    2000 XPL
    2002 XPL 67mph GPS
    twin pipe build up link
    http://www.pwctoday.com/showthread.php?t=204126
    If you want more inches STROKE IT!
    Feb 2004
    There is plenty of space there to hold that guage.
    Temp guage ? Easy enough, just replace oem temp sender to beeper with the proper temp sensor for that temp guage. Problem is matching thread sizes in head. I made an aluminum water manifold with a temp sensor and connected it to the water line leaving the head at the back of the head, then used an aftermarket boat water temp guage like that one from Harbor Frieght. I kept the beeper and overheat sensor on there too..
    Top Dog
    Nov 2006
    Twin Lakes ID
    Quote Originally Posted by Bill O'Neal
    Agreed, but so would Harbor Freight's $3 DVM! [grin]
    Mar 2007
    MA
    I am going to try that. What did you use to make the manifold?
    3 96 XP's
    2000 XPL
    2002 XPL 67mph GPS
    Frequent Poster seadooVA-NC's Avatar
    Oct 2007
    Virginia Beach, VA
    Nice looking tach. Wish they had a $20 trim gauge...
    1996 SPX
    bone stock
    trim works, gauge doesn't
    no fancy paint
    ridden every weekend
    What more do you need?
    Top Dog
    Nov 2006
    Twin Lakes ID
    You could probably make the voltage gauge work. I believe the trim uses a varying resistance based on a magnet passing by reed switches that switch in different fixed resistors. You could create a voltage divider that would yield a variable voltage that would move the voltmeter.
