Results 1 to 10 of 18
    Aug 2008
    Victoria, BC CANADA
    Engine clicks but won't turn over
    Hello, I got a new muffler hose and battery the ski started up lots more power but shut it off and when we tried to resart it, I can hear a click and thats it opened the black plug on front of motor it is triying to turn the wheel but it can't seem to do it. Any ideas on were to start?
    Thank You
    Lawrence
    I dream skis markmarvin30's Avatar
    Mar 2008
    East Lansing MI
    Re: Engine clicks but won't turn over
    What type of tigershark is it?
    Look in the pump from back and from under. See if there is anything in it.
    Take the plugs out and try to turn it by hand from the back of the engine. you will probably have to take off the cover to the engine coupler.
    Aug 2008
    Victoria, BC CANADA
    It is a 1993 I can not turn buy hand I put towel around drive shaft and it moves a very little.
    Thank You
    PWCToday.com Is My Home Away From Home 1goofball's Avatar
    Golden Gulf Coast, MS.
    take your spark plugs out and see if it will turn over. If so, your battery doesn't have a good charge.
    Aug 2008
    Victoria, BC CANADA
    I will go try that now but I Just bought brand new sealed gel battery, even tried jump starting
    Thank you lawrence
    Aug 2008
    Victoria, BC CANADA
    No luck still just clicks.
    frustrating !
    look in your electrical box for starter relay (solenoid) and put a screwdriver between the 2 posts. If it turns over, you need a new one. If it does nothing then its good and will have to look somewhere else. Also clean and tighten your battery, starter and ground cables.
    Mar 2008
    East Lansing MI
    Can you turn it by hand with the plugs out. It is easier.
    Also there may be a notch in the driveshaft somewhere that will fit a 17mm wrench. This may help to turn it.
    Aug 2008
    Victoria, BC CANADA
    I can not turn with plugs in or out I can rock it 1mm or less with a wrag around shaft with monkey wrench. We are just going to the lake now with the 89 Kawi so the kid can ride and I'll wrench I will try the solenoid idea
    Thank You everyone for your help
    I will tell you more later today
    I had thought the starter might be stuck out against the fly wheel?
    Thanks agian
    Lawrence
    Mar 2008
    East Lansing MI
    Sounds to me that something is broken and stopping your engine from turning. I had a buddy that had the stator parts come apart and bind up the flywheel. Big mess.
