1992 Waverunner 500 oil mix ratio?
I assume these are premix because I don't see the auto lube set up or iol tank,so what ratio should I mix it at? I also have a 1991 VXR and I see it has a block off plate where the oil pump was at. The 500 didn't come injected? or am I missing something??
Re: 1992 Waverunner 500 oil mix ratio?
50 to 1 is what the pump put out at max but I would premix 40 to 1 to be safe
Yamaha
All but 800 & 1200pv 50:1
800 & 1200pv 32:1
I don't see a oil pump,tank or blockoff anywhere on this motor.Was it premix from the factory? I have a VXR 650 and it has the block off plate,and I know it used to be injected,but I don't see any evidence that the 500 was injected.
no clue? I'll look into it
sure looks like your correct! I can't find an oil pump or tank in the microfiche
Thank you,I thought so but wanted to verify by someone who know,as im new to watercraft.
- You may not post replies
- You may not edit your posts
Forum Rules
