Results 1 to 10 of 10
    Jun 2008
    Richmond, Virginia
    Primer Kit ZXI 1100 Installation
    Ok, YES I know there are A LOT of threads regarding this, but I want to make sure that it is done RIGHT. I have seen so many different directions people have gone. Ok, on installing primer kit, remove choke butterflies (3), and remove complete choke assy. Here is where I need help, remove the plastic piece? This is the plastic piece on the sides of the carbs? Like that the choke rod actually goes through and rides on the carbs? Then after removing those, you press in the brass fittings, do you put fittings on both sides of ALL three carbs, one side of all three, one side of just one? Also if you only put the fittings in one side, do you have to plug the other side where the choke shaft used to be? One more thing, the existing places where the oil lines used to run from the pump into the carbs, do those fittings need plugged as well? Thanks in advance for the help
    Jun 2008
    Tennessee
    Re: Primer Kit ZXI 1100 Installation
    Is there any start to finish instructions on this?
    Jun 2008
    Richmond, Virginia
    I pretty much know the start to finish instructions from piecing them together from about 20+ threads and 4+ people....what a joke
    PWCToday Newbie mrscary3721's Avatar
    Apr 2008
    Corona, CA
    Yes, you need a nipple-type fitting on one side of all three carbs. You then need to plug the other side where the choke shaft used to be. The existing places where the oil lines used to run from the pump into the carbs do need to be capped. Auto parts stores sell small rubber caps that resemble a condom ( an 1/8" condom...) for sealing the old oil lines after switching to a premix setup.
    I dream skis carlosburitica's Avatar
    Sep 2009
    fort lauderdale
    look for my latest post with pics
    Aug 2009
    memphis tennessee
    The above I guess is the traditional way most people do it. But, I wanted to keep my chokes, so I just drilled a 5/16 in hole in the rim of the carbs and inserted my brass fitting. that way, i still have a choke and my stock air cover.
    Just an alternative option.
    I dream skis PEVO's Avatar
    Feb 2009
    Central Tx.
    1998 1100 STX Stock
    Pre-mix, Fuel Primer & keyed battery disconnect installed
    2000 900 STX Stock
    Aug 2009
    memphis tennessee
    That is a good looking set up.
    Have any of you guys noticed an increase in gas fumes or gas smell in the hull after you put the primer kit in and the ski sits for awhile?
    Seems like mine had more of a gas smell, but I am not for sure.
    Nov 2014
    tampa
    Does your method of priming interfere with the operation of the carbs? Does your method produces a quick start . I asked because I was thinking of the same idea.
    Mar 2008
    southern ca
    Quote Originally Posted by PEVO View Post
    Very smart man!
