how much do they weigh?
so im just trying to figure out how much my two skis weigh.. i checked sea-doo.net but i refuse to belive that my 92 sp weighs just as much as my 97 xp... is there anyone could tell me what they actually weigh??
reason being, i love my truck but its killin me on gas.. i need something that gets better mpg but can still two my skis..
Re: how much do they weigh?
Download the free shop manuals at the top of the form. Should give the specs in there. They did for mine... 1995 SPX just under 400LBS...
Drag your ski's to your local truck stop and put the whole set up on the scale. That way you will know the complete weight that you are towing. I did this a couple of years ago with my motorcycle and trailer and it cost like $12.00.
Top Dog
I tow 2 seadoos (SP & GTS) on a double trailer with my 2.2L 4cyl Subaru. It's great on the boat launch ramps because it's all wheel drive. She's got 180k miles but tows the weight without hesitation. I'm guessing it gets around 22-24MPG while towing.
1998 GSX Ltd
you think your skis are bad? my two sleds trailered cost me $80 to fill i can only squeeze about 200 miles out it!
well if your towing those two with a 2.2 4cyl subaru i wonder if a 4cyl ranger or s10 will be able to tow mine with ease..
Shouldn't be a problem..
I use an '87 Dodge Daytona... 2.2 turbo, fwd, manual transmission. I tow a double trailer with my '94 XP and '97 SPX. Never had any problems at the ramps... other than not having enough ground clearance (it's lowered) to make easy launches when the water is low.
Oh, and it has over 200k miles on it.
'97 SPX
'94 XP
Tech Guru
I had a 1988 2.2 liter Toyota pickup that towed watercraft daily 300 days a year. You just need to be easy on the brakes and the clutch.
The biggest concern should be what brakes you have to stop the load when thinking about trailer loads. A small towing rig sucks in the rain because it will not stop.
- You may not post replies
- You may not edit your posts
Forum Rules
