650sx conversion ski fixed steering - Page 2
Page 2 of 18 FirstFirst 123412 ... LastLast
Results 11 to 20 of 179
    May 2007
    the big O
    Re: 650sx conversion ski fixed steering
    any updates?
    Resident Guru Mackzilla's Avatar
    Feb 2007
    Douglas , Ga.
    Great looking project Terry,That looks like it will be a great ride!! Forget Ugly that looks good to me!! We call that southern style,lol !! Great job on the Mod !! Lookin Good!!!
    MACKZILLA JETUNLIMITED
    No updates yet ,frankly I have been too busy to work on it,as strange as it may sound I have been wrapped up pretty tight,I need to get some more pour foam and epoxy resin and I will start working on the new hood within the next month or so,right now trying to get some steering systems and footholds built for Daytona.
    Time for an update I guess,I totally forgot about this thread!
    May 2007
    the big O
    So your using an X-2 steering stem? I thought the steering arm stuck out the wrong side? How did you fix that?
    With a different kind of X2 steering arm.
    The foam came in yesterday so I foamed the areas in the hood in,I was looking for a way to add some foam back to the ski since I removed the gunwales,as you can see there are two large areas built into the hood,those are foamed now and I will add some foam to the top of the hood today to build it up some,then I glass it all up.My hope is that this will be enough floatation to make the ski right itself if it happens to end up upside down again.I will be testing it to find out for sure,if you look closely at the first pic you will see the cat underneath the hood ,he thinks the hood is a playhouse.
    Foamed in the front and then I glassed it over,I also foamed the hood to match up to it,I will be glassing the hood today and doing some more cutting and glassing on other areas as well.There will be a lot more work going into the front nose area of this boat but the front lip will not be going back on.
    I routed out for an insert for the hood straps,installed the insert and reglassed the front section,I also did some cutting and reshaping on the dash.
    Glued a piece of foam to the nose shaped it and glassed it in,no more blunt nose ski!
