Results 1 to 10 of 12
    Jul 2004
    Margaritaville, State of Mind
    2002 GTX DI Info..
    hello, I just picked up a 2002 gtxDI, and i was just wondering how fast it should go? on smooth water? and what RPM should it pull at full throttle??
    also , does anyone else have the foam near the exhaust melting away?
    thanks a lot,, any other info i should know about this boat?
    thanks a lot,,,
    Mike
    Its time for a cruise down A1A to my old home town.
    2002 Sea-Doo GTX-DI
    GERFF
    Guest
    Re: 2002 GTX DI Info..
    you need to check the power valves that they are clean and orings are not blow out and change the pump fluid..
    Feb 2008
    Australia
    I have the same ski and can tell you this much.
    Max RPM 1 up is about 6820-6840rpm depending on load and water conditions. Max speed according to my GPS is 86km/h (53.4mph), this was recorded with 3/4 tank of fuel and me riding (about 115kg).
    On smooth water mine will pull 6800-6820 with 2 riders and do about 51-52mph. Dobnt look at the speedo, it reads way low in my case.
    Assuming that youhave no mechanical issues and that the impeller and wear ring are in good condition you shouls also see the same as me.
    How many hours has you ski done? I would suggest you remove an clean the RAVE valves, replace plugs and fuel filter. Also make sure you run it on premium, they do not run right on regular.
    Jul 2004
    I wonder why the 02 gtx di is slower than the 01 gtx carb model, i used to have that and it pulled about 59-60 mph
    the manual reccomends regular gas?? ive used regular the only time i had it out..... your saying it runs better on the premium? and yes, i will have to check the rave valves and the fuel filter, i dont know what there condition as i just bought the seadoo, the plugs were just done by the dealer who i bought it from...., ,,, it has 112 hours on it... and it seems to run great...
    Mike
    2002 Sea-Doo GTX-DI
    PWCToday Regular WPAbrams's Avatar
    Jul 2007
    Lexington,SC
    Didn't the body of the ski change in 02 and the 02 is heavyer by about 100 lb's. I have a 01 carb model and it will blow away the di's
    Feb 2008
    Australia
    Quote Originally Posted by assman300
    I had issues running my 03 GTX DI on regular and also found that it was detonating after removing the RAVE valves and inspecting the piston tops. I would not risk it because if you melt a piston or damade the rings then it will be a costly rebuild.
    Like I said my 03 did just under 54mph couple of weekends ago. I suppose the conditions were 90% of what you would call ideal and I am not lightweight either. Will less fuel and a lighter rider the ski may do 55-56.
    The 02/03 GTX DI models have a different hull to the 00/01. The later models have a bigger hull, much like the GTX and RTX today. The 01 model is lighter and has a shorter hull, so I think this explains why it would be 2-3mph faster. I imagine it would get there faster too.
    Here are some specs:
    2000/01 GTX DI 130HP
    HORSEPOWER 130hp
    HEIGHT 41" (104cm)
    LENGTH 124.1" (315cm)
    WIDTH
    48.1 (122cm)
    DRY WEIGHT
    681 lbs. (309kgs)
    SEATING
    1, 2, or 3
    OIL CAPACITY
    1.6 gal. (6L)
    FUEL CAPACITY
    15.0 gal. (56.5L) (91 Octane minimum)
    HULL MATERIAL
    Fiberglass
    HULL TYPE
    Deep Vee
    STORAGE 23.4 gal. (88.6L)
    2002/03 GTX DI 130HP
    HORSEPOWER 130hp
    HEIGHT
    44.1 in. (112 cm)
    LENGTH
    130.4 in. (331 cm)
    WIDTH
    48.1 in. (122 cm)
    DRY WEIGHT
    715 lbs. (325 Kg)
    SEATING
    1, 2 or 3
    OIL CAPACITY
    1.6 US gallons (6 liters)
    FUEL CAPACITY 15.0 gal. (56.5 liters) includes reserve
    HULL MATERIAL Fiberglass
    HULL TYPE
    Modified Vee
    STORAGE
    52.6 US gallons (199 liters)
    PWCToday.com Is My Home Away From Home 1goofball's Avatar
    Golden Gulf Coast, MS.
    my 2000 RX carb runs 7000rpms and 64mph (stock)
    my 2002 RXDI was only running 6500rpms at (guessing 53-55mph)
    so I started looking for a problem. I found a piece of exhaust manifold broken off on inside of manifold. Hasn't been put back together, but I believe that was problem.
    Tech Guru PWCToday.com Is My Home Away From Home Bill O'Neal's Avatar
    Feb 2004
    Glendora, California
    No stock carbureated GTX does 59-60, more like 53 mph, and a RX goes about 61 tops. You guys are dreaming.
    Shortly after introducing the DI motors, the fuel spec was raised to 91 octane because pistons were breaking when run on 87 or 89 octane. My 2001 manual clearly states not to use less than 91 octane fuel.
    I have a DI in here right now because the owner ran old gas and said he buys 89 octane. This is the 4th DI this year in here for the same problem.
    Bill O'Neal
    email Chris at my shop cdofixr1@live.com
    Weekdays, (626)914-9509
    my carbed RX did 64mph with 85lb son laying on seat with 2 gallons of gas and VTS up, on smooth lake, wind behind him and we at sea level.
    The dream-o-meter was 71mph
    Jul 2004
    I had a 2000 GTX Carb,, and i clocked it at 59 MPH on the GPS,, and im a hefty 300 pounds,,,, may of been quicker with me 5 years ago on it
    Mike
    2002 Sea-Doo GTX-DI
