LASERMAN Sport Cruiser Restore #2 - Page 35
Page 35 of 35 FirstFirst ... 25333435
Results 341 to 345 of 345
  1. #341
    Nov 2018
    MO
    Re: LASERMAN Sport Cruiser Restore #2
    Hello all, new to site. Was wonder if the bottom a 1991 Kawi sport cruiser was paint or gelcoat, and ideas on how to redo?? Thanks
  2. #342
    Nov 2018
    Thienan5811
    Quote Originally Posted by afcblink View Post
    Looking at that with the steering console stripped totally changes the looks of that hull -- much less massive. That thing's just screaming for different steering arrangement. I could really see glassing that front end flush and rigging up something like a stick-steer lever next to the seat, a la panfishing boats.
  3. #343
    Jun 2013
    illinois
    All older Kawasaki's are painted. No gelcoat because the hulls aren't fiberglass. They're SMC or FRP - I forget. sheet molded compound or fiber reinforced plastic. You can repair them with a cheap fiberglass made by bondo repair kit. I use SC110 I bought off ebay. It's more expensive but it's actual EPOXY resin, not the polyester resin you can pick up locally. It works great for big repairs as it has almost an hour working time until it starts setting up. If you're going to touch it up with white paint get the Rust-oleum Appliance Epoxy. If you do a good job you won't even see the touch up area at all. Gel coat will crack and chip easily so if you're doing the whole bottom just sand it and paint it. Good luck with your SC. We've had ours going on 10 years and love it.
  4. #344
    Nov 2018
    MO
    Thanks for the advise. Sorry to say I am 44 years old and this is my first jet ski. Not sure why I waited so long. It runs just fine just want to fix it up for my kids. Does the prosses you described to fix the bottom going to be the same for the whole hull. And when I am done to I wet sand and buff or just paint and ride? Thanks again and sorry for the dumb questions. Any more suggestions would be great.
  5. #345
    If you have painted it correctly you ride it like a rental, if not you sand and buff to remove whatever paint mistakes occurred, the whole boat is SMC so epoxy only for any repairs.
    WWSRD , What would Speed Racer do ?
