1997 Tigershark Bendix replacement - question - Page 2
Results 11 to 15 of 15
    Frequent Poster tahoeking's Avatar
    Sep 2010
    Anywhere but Mexico
    Re: 1997 Tigershark Bendix replacement - question
    Quote Originally Posted by hemmjo View Post
    Some have suggested filling the cover with 2 cycle oil... ....Maybe just enough to touch the bottom of the flywheel when it is stopped,
    You have got to be kidding!!! That area is to be DRY!!! Fluids of any type in that area can cause stator issues/failure.
    If you are finding oil puddling inside chances are you have a partial blown crank seal. Hence the need to PULL THE MOTOR!
    '93 Sea-Doo GTX
    '94 Montego
    '94 Sea-Doo GTX
    '94 Yamaha VXR
    '95 Daytona
    '97 Montego DLX
    Oct 2013
    Ohio
    As I mentioned I DO NOT recommend oil in there. Instead I have suggested ways to be sure it stays dry.
    In addition I must add that many electrical devices run in oil filled environments. So it is not as extreme an idea as you might think.
    You are correct that having oil in there would MASK an issue with the crank seals which is not a good thing.
    John
    Sep 2010
    Anywhere but Mexico
    My goodness.... Had to go there didn't you. Yet proof that arrogance and clueless remarks go hand in hand. Your statement, if made in the company of my colleagues would be considered foolish.
    '93 Sea-Doo GTX
    '94 Montego
    '94 Sea-Doo GTX
    '94 Yamaha VXR
    '95 Daytona
    '97 Montego DLX
    I have used a shot glass of oil in the past and have had no problems, and the bendix has never stuck
    Aug 2017
    Peterborough, Ontario
    Quote Originally Posted by tahoeking View Post
    Comments like this aren't helpful.. hope this guy is no longer active on this site.
