1997 Tigershark Bendix replacement - question
Results 1 to 10 of 15
    May 2008
    Michigan
    Hi: I am new to PWC's and I'm new to this forum. I bought a package of two 1997 Tigershark's, a 770 and a 1000. Although the seller started them for a second at HIS house, the very first time I tried to start them at my home, the 770 would not start.
    The starter actuates, but does not engage the bendix. It whirls, spins, or whatever, but the PWC does not turn over.
    Reading this forum points to the need for a new bendix. I found one on eBay and I'm in the process of installing it myself. I read one of your posts where it explained the replacement the bendix, but I have a question.
    The front cover has a plug that unscrews to verify fluid levels. When I removed the front cover, only a very small amount of greasy, thick liquid rested in the bottom of the cover. Am I supposed to add anything other than a lot of marine grease to the bendix itself? Am I supposed to add any oil, lube, grease, or any other lubricant to the inside of the cover after it is reinstalled?
    Please reply if you can. Thank you.
    Richard
    Regards,
    Richard
    ArcadeNut@aol.com
    Resident Guru slag's Avatar
    Jul 2002
    Lawrence, Kansas
    Re: 1997 Tigershark Bendix replacement - question
    add nothing.. its a timing inspection hole
    I use just a little moly or synthetic grease to the bendix and reassemble it. Clean the crud out of the bottom of your front cover and make sure it makes a watertight seal when putting it back together.
    PWCToday Guru KIwi Mike's Avatar
    Christchurch, New Zealand
    Also remove the bellows under the starter and plug the hole. Then go out and thrash it!!
    PWCToday's first Tigershark owner Moderator
    lownrangr's Avatar
    Nov 2001
    I can hold up my hand and point to where I live. Can you?
    before i installed my new bendix in my 1100, i think i sprayed it down with wd-40 just for ****s and giggles. I don't know if it helped any but, it can't hurt i guess. Fluid Film would work even better.
    btw, i used a graphite grease made by polaris that i found at the dealer.
    Region 6
    Shark Bait
    #713
    My race boats:
    1999 Tigershark 1100R (ret.)
    Novice 1200 Stock
    1996 XP
    800 Limited and 1000 Superstock
    2017 Achievements
    4th at World Finals Pro-Am 1100 Superstock
    5th at World Finals Am 1100 Superstock
    7th at World Finals Am 1100 Limited
    Thank you to my sponsors: GoPro, AMSOIL, Riva Racing, Incase, Shorai, ODI Grips, and Ryno Power.
    Check out my Facebook page: https://www.facebook.com/TripleLRacing/
    May 2008
    Michigan
    Thank you for the replies. I've installed everything and will try to start it tomorrow.
    Richard
    Regards,
    Richard
    ArcadeNut@aol.com
    Jul 2002
    Lawrence, Kansas
    fwiw, the starter gear or bendix can sometimes be resurrected by soaking it in diesel for a few days or some oily/gasoline mixture. Work it a bit and it should be good to use again.
    Feb 2007
    northwest ohio
    Guys, about how long am I looking at to replace the bendix on my 770? Very mechanical, not a newbie, just don't see many tigersharks or if I do, they don't normally need the bendix replaced.
    Regards,
    Jul 2002
    Lawrence, Kansas
    Well, you have to remove the front cover. I sold my tigershark long ago and don't know how much room you have in front of the engine. Once the front cover is off, you will need to remove the flywheel with a puller. Then, take the bendix out, replace it with a new one, reinstall the flywheel, replace the front cover (make sure it seals back up so you don't get water in the front cavity), then go have fun. Length of time is dependent on many factors, but plan for at least a couple hours if not more.
    I recommend checking out this thread on it:
    http://www.pwctoday.com/showthread.php?t=431345
    Frequent Poster tahoeking's Avatar
    Sep 2010
    Anywhere but Mexico
    Quote Originally Posted by duricekauto View Post
    Regards,
    Save yourself the cut and busted knuckles..... go ahead and pull the engine. While out you can inspect, tighten, replace, rebuild, etc.... things you can't normally get to with the engine in place. In the long run you'll be glad you did. Considering the shark's age, it would also be a good time to remove the 2-cycle oil injector pump and go to a 40:1 pre-mix fuel. Be sure to cover the hole where the pump was mounted (or leave pump in place with oil lines removed) as well as block off oil injection points on the intake manifold.
    ENGINE REMOVAL NOTE: Be sure to mark location of motor mount shims (if any) and reassemble in like fashion.
    '93 Sea-Doo GTX
    '94 Montego
    '94 Sea-Doo GTX
    '94 Yamaha VXR
    '95 Daytona
    '97 Montego DLX
    Oct 2013
    Ohio
    I got mine out in about an hour. Had to make a flywheel puller, that time is not included in the removal time. My mag housing was 1/2 full of water. After the cover and flywheel off, the starter bendix out, it was a rusted mess, I soaked it in PB blaster, for a couple days and got it to move but had to take it apart to really clean it. Found a broken spring, so I had to get a new one. I have a great auto electric place here that repairs starters and alternators, they got me a new bendix for 56.00.
    I got some CorrosionX http://www.corrosionxproducts.com/corrosionxpage.htm to spray inside before buttioning it back up.
    I am also going to drill and tap a fitting in the bottom of the cover to attach a hose so I can easily check and drain any water, also flush if it gets wet.
    I agree with removing the bellows, I am going to attach a hose there also with a plug in it, leading up to where I can get at it.
    I would NOT pull the motor to do this UNLESS you have other issues to deal with. You will need a mirror to put down in the boat so you can see what you are doing.
    Some have suggested filling the cover with 2 cycle oil, I would not recommend doing that, it takes a lot of horsepower to turn the flywheel in all of that oil, it will also make the oil foam and there will be less air space for expansion with things warm up. Maybe just enough to touch the bottom of the flywheel when it is stopped, then it will be thrown all around inside on start up and the flywheel will not be running in oil. I am just going to spray the inside CorrosionX and keep track of moisture inside after each ride.
    Good Luck,
    John
