Results 1 to 10 of 12
    May 2008
    Ca.
    94 Wave Raider - Dead - Need Help!
    My 94 Wave Raider is dead. It acts like it has no battery. I tried charging and jumping with and without the battery in place.
    I checked the main fuse, both visually and with a meter, it's fine.
    I know how to work on cars, but need some help diagnosing this thing.
    I have owned it since it was only a year old, and it has been totally trouble free except for the occasional battery.
    I am thinking the first place to start is with the start button, but which two wires do I short?
    And if that's not it, what next???
    Thanks in advance.
    Paul
    May 2008
    Ca.
    Anybody????
    Can't be that difficult a question...
    PWCToday.com Is My Home Away From Home ZMANN's Avatar
    Jan 2006
    AZ
    Re: 94 Wave Raider - Dead - Need Help!
    I would guess the selenoid but here is the tests
    http://www.hydrotoys.com/gpr/tuners/...DER_MANUAL.pdf
    http://www.pwctoday.com/image.php?type=sigpic&userid=15348&dateline=1238301767
    I dream skis Relentless's Avatar
    Jan 2006
    Austin, Texas
    Does it click from the electrical box, when you hit the start button, and the lanyard plugged in?
    The wires running down from the handlebars... Trackthe black & white wires, and find the connector. Disconnect it and try to start it.
    Take the sparkplugs out, and try to turn the engine by hand using the rear coupler.
    Pull the starter and test it
    Frequent Poster jetskier90's Avatar
    May 2007
    Vashon, WA
    if you unplug the red/brown wire click and short them together it should crank the starter.
    '94 Yamaha WaveRaider 701
    Jul 2005
    cleveland,tn
    It seems that jet skis are very suceptable to electrical connection corrosion. First thing I would do is inspect and clean all the plugs and connection that you can find.
    With the information you supplied, my first guess would be one of the main cables to the starter relay or the fuse. There are several connection that would cause total lack of any response from the start button, so just start checking from one end to the other. It is unlikely to be the starter its self since you get no clicking from the relay.
    PWCToday.com Is My Home Away From Home chatty's Avatar
    Jun 2005
    san jose,ca
    just had this issue on my 1100 at the weekend, was the starter switch.
    one of many reasons.
    2010 MH 300 Endurance Champion VX 110 Class (Ironman) - SUR #119 - AWA because you know you should!
    DJSA Rocks!
    Jun 2005
    san jose,ca
    http://www.pwctoday.com/attachment.p...0&d=1211679805
    I took the switch apart, put it back together and all was well.
    the cables can be unclipped at the bottom of the steering column to test them.
    DJSA Rocks!
    May 2008
    Ca.
    Thanks everyone!!! From no replies to several!! I appreciate them all and will post back after I have checked them out.
    May 2008
    Ca.
    I was on the right track. Once I figured out which wires went to the start switch, I jumped them and that is the problem. Man, if I had only kept going on Friday. I had the connector apart, and was going to jump them, but decided I had better not plus I ran out of time. jumping the wires allows it to turn over fine, but the battery still needs a charge. I am guessing that it will start fine once I get a good charge on it. Now I am off to figure out how to pull and or repair the switch. I got the cover off, but it looks like I need to take more off.
    I will write back.
    Thanks again.....
    Especially for the link to the manual!!
