    Jul 2007
    NJ Coast
    Idler gear (starter bendix) replacement
    I need to replace the idler gear (starter bendix) on a 96 Yamaha 1100 Wave Venture. I assume that I do not need to take out the motor.
    Does anybody know which components need to be removed so I can gain access to the front cover and remove the flywheel?
    thanks in advance.
    ebird
    May 2008
    Mobile, Al
    Re: Idler gear (starter bendix) replacement
    Hehe.. I just did this yesterday. It's not too bad and took about me about 2 hours. I just bought a 1995 yamaha waveraider 1100 that had wouldn't crank. I checked the starter but after reading a bunch of the posts here I found it was the bendix.
    On the raider, I had to pull the gas tank out and I had to remove the power pack (CDI) cover and take off the flywheel cover (8 - 10 bolts). I then used a flywheel puller to remove the flywheel. Once I pulled the flywheel the bendix fell out. It was locked up from rust so I cleaned it, oiled it, and slapped it back in. The ski cranked on the first try after sitting for over a year with no care.
    Hopefully this will help you.
    Spatch!
    Jul 2007
    NJ Coast
    Thanks Spatch, It's windy today so I think I'm going to dig in to it.
