Real tuning specs Factory Wet Pipe -750 - Page 3
Page 3 of 7 FirstFirst 12345 ... LastLast
Results 21 to 30 of 64
    Resident Guru slag's Avatar
    Jul 2002
    Lawrence, Kansas
    Re: Real tuning specs Factory Wet Pipe -750
    good question. the guide over at sbtontheweb only goes to 440. here is what they have
    440 - Low Speed 1
    High Speed 5/8
    p.s. you should make your own thread and post there. This is about factory pipe carb settings.
    Sep 2007
    In the water
    Just tuned up the ski. I need a little more snap off the bottom and I will be satisfied.
    Location Buffalo, NY -
    1992 750 sx small pin
    Factory wet pipe settings: top 3/4 turn out
    Middle closed
    Bottom 1/8 open
    44mm black jack settings: Main jet - 165 @ 2 5/8 turn out
    Pilot jet - 120 @ 3/4 turn out
    Peak rpm 6950 - 6990 very steady
    Pop off was 20 psi , i raised it a bit by elongating the spring a touch with a gentle stretch. I have yet to check it with the gauge.
    Dual cooling oem to manifold and new/2nd line top fed into the pipe.
    FCV set at stock i believe it comes at 3.5 psi. I may try raising that to 5 psi. 4mm restrictor between the FCV and stinger pipe.
    compression front is 181 and rear is 179 psi.
    82.00mm wiseco pro-lites
    skat trak 9/17 standard
    blowsion freestyle pump cone
    top loader intake grate
    R&D flat ride plate
    Factory pipe water box
    I had trouble tunning and removed the vilder flywheel and replaced it with the stock one. I may try using the vilder again to see if I can get more of a touchy throttle.
    Any suggestions would be great, Thanks
    PWCToday Regular Mr. Gizzard III's Avatar
    May 2005
    Safety Harbor, FL
    Anyone running the 88 low jet, 155 high jet that Factory Pipe recommends with the wet pipe and having success? I am having trouble getting the low-end dialed in. They recommend 5/8 out on the low, but the ski isn't getting enough fuel at that setting. I currently have it at about 1 full turn out. It's sluggish out of the hole for about 1-2 seconds, then it hits and about pulls your arms out of the sockets. Other than the low end, the throttle response is great.
    89 Kawi 550
    93 Kawi 750sx
    01 Kawi zxi1100 Couch
    Sep 2007
    In the water
    You might want to try a FCV to clean up the low end.
    Try opening the low screw to 1.5 turns and see what happens. Always safer to go rich than lean.
    Single carb setup? Stock?
    May 2005
    Safety Harbor, FL
    Ya it's the single Keihin carb. What do you mean by FCV? 88 is a pretty fat jet, so the way the ski is reacting is leading me to believe that there is too much fuel on the low end. I am using the stock spring, needle seat. I think opening up to 1.5 will bog it down more.
    89 Kawi 550
    93 Kawi 750sx
    Sep 2007
    In the water
    I just got my carb to a decent point this weekend. I feel your pain. I tried everything before changing jets. Screw in / out kept track on paper how it handled. Then change jets. It only takes one time of the old"why did I not try closing the screw on that last jet" then your replacing the jet with the last. I was very systematic in my approach, trying lean and rich conditions first then see what worked. After that small 1/8 turns to see just where it was. I wish I had a larger main becuase 2 5/8 out is way too much. I tuned my low end by turning the high screw to 1/4 out and only running 50-100 feet to see how the low jet/screw mix was performing. Then open the high screw to what worked great for top end.
    Sep 2007
    In the water
    Sorry FCV is a Flow Control valve. It dries the waterbox out during low throttle rides. Supposed to give the throttle a bit more snap.
    May 2005
    Safety Harbor, FL
    I was thinking about putting the flow control valve in. Thanks for the input. Hopefully others will post their jetting specs and conditions on this thread. No two carbs are a like, but getting a close starting point really helps.
    89 Kawi 550
    93 Kawi 750sx
  9. #29
    Sin City USA
    River Rat my bad I thought you had dual carbs when I suggested 80 pilot!
  10. #30
    Resident Guru jfw432's Avatar
    Jul 2007
    GA
    Quote Originally Posted by Mr. Gizzard III
    I ended up using an 85 jet in my ski at about 1.5 turns out and it works great. I can idle it for 20-30 seconds and it'll still snap with little to no hesitation if I juice it.
