Real tuning specs Factory Wet Pipe -750 - Page 2
Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 64
    Top Dog iceracer's Avatar
    May 2006
    wi
    Re: Real tuning specs Factory Wet Pipe -750
    a single 46 and manifold would wake that ski up !!!!
    PWCToday Newbie redkawi750sx's Avatar
    Mar 2008
    richland wa
    OK guy's here we(I) go... I got duel 44's MIKUNI, I'm running 125 main and 80 low 115g spring 2.3 N&S my ski revvvvvvvvvvvvvv'sssssss and I have to pull lanyard , even then it took a second befor it turned off........I need alot of help and they are also GRS carbs if that make's any difference.....PLEASE HELP THANK'S
    My KAWI 750sx mod's
    18'' worx ride plate
    R&D grate
    R&D pro series 28cc head
    R&D pipe
    V-FORCE 3's
    R&D dominator intake
    duel 44 GRS carbs
    westcoast exaust manifold
    blowsion duel fuel pickup
    red tau ceti arrestors
    just 2 name a few!!!!!!!!
    May 2006
    wi
    I built a 750 x2 with twin 44 mikuni's...I would not recommend any lower than 95 lows ski is currently 95 low and 135 high...two turns out on the low and 1 1/2 out on high...pop off set @ 18 psi...ski runs fine but the next time carbs are off I'm going to up the low to 100 or 110 ...the reason your ski is reving is because of a lean condition...fatten it up on the low and you'll be good.. at least start where I'm at ...the ski has run this way a whole season!!!!
    Mar 2008
    richland wa
    what gram spring are you running????? thank's !!!!! bro
    My KAWI 750sx mod's
    R&D grate
    R&D pipe
    V-FORCE 3's
    duel 44 GRS carbs
    Sep 2007
    In the water
    Any suggestions with jets/tuning specs:
    1992 750 sx -
    Factory wet pipe - W/FCV
    Factory pipe products water box
    Vilder light weight Charging Alum Flywheel -
    44mm Single Black Jack Carb
    Blowsion Reed Spacer
    R&D - Reeds Cages and Stuffers
    MRD Girdled Head
    82.00mm Wiseco Pro-lites
    Crank - Trued and welded
    Dual Cooling
    Skat Trak Prop the old style - standard 9/17 (its marked in degrees)
    Blowsion Freestyle pump cone
    Any help is greatly appreciated
    Frequent Poster RossThaBoss11's Avatar
    Apr 2008
    Connecticut
    hey guys any ideas on what size jets to get for my 650 sj with a head (175ish psi), exhaust, intake and reeds?
    Jun 2007
    Redding Cali
    I have an 01 sxipro, sxr carbs, factory wet pipe, lightend flywheel, msd ignition, ada head (185psi), water injection, vforce reeds, nd prok arrestors, i had an 80 pilot, nd my ski was really fat on the bottom, i took it down to a 75, at 1.5 turns out nd it hits hard off the bottom now!! im also at about 600-1000 feet elevation.
    PWCToday Regular Firefighter's Avatar
    Jun 2007
    White Lake Michigan
    93 750 SX
    40 mm Keihin, Aftermarket Flame Arrestor.
    Factory Limited Wet Pipe w/Stock Waterbox.
    Low Speed Jet 80 @ 1 1/8 out
    High Speed Jet 155 @ 7/8 out
    800-900 Feet Above Sea Level, 83 Degrees, High Humidity, Michigan.
    Ski Absolutely Rips! If nothing else I'm going to lean out the water injected into the exhaust.
    Resident Guru jfw432's Avatar
    Jul 2007
    GA
    Quote Originally Posted by Firefighter
    93 750 SX
    I had forgotten about this thread but after changing jets, those are pretty much the settings I run right now in GA. I'm running low at 1.5 turns and high at 1 turn. I think it's actually a little rich but better than a little lean especially since the water is getting really warm down here.
    Jun 2008
    lake orion
    what are the settings for a stock 300sx? what are the stock turns out on both low and high needles?
