Real tuning specs Factory Wet Pipe -750
Page 1 of 7 123 ... LastLast
Results 1 to 10 of 64
    Sep 2007
    In the water
    Factory Pipe Specs:
    Please Post your tuning specs (jet sizes, springs, needles, pop off etc)
    I have realized that the specs included in the instructions are a good starting point but no exact as all motors are not created equal.
    Post your engine mods with what you have found to be your best tunning specs.
    Also location , as that plays a role as well.
    PWCToday Newbie s3b0's Avatar
    Mar 2008
    Germany - Ingolstadt
    Re: Real tuning specs Factory Wet Pipe -750
    its interesting for me too, im standing before the same question...
    Resident Guru jfw432's Avatar
    Jul 2007
    GA
    Well I'm certainly not perfect but here is my current setup. I ride in Macon, GA which is roughly 350-400ft above sea level.
    I am running stock spring and needle.
    Low jet - 75 at 2 and 1/2 turns out (I plan to get the 80 and 85 jet soon because 2.5 turns is a bit too much)
    High jet - 155 at 1 and 1/8 turns out (Never had any problems on the top end but I also don't think I've reached top speed either and certainly don't stay at those speeds for more than a few seconds)
    My ski hits incredibly hard at the bottom and is smooth all the way through the rpms. However, if I idle for more than 10-15 seconds without touching the gas and then nail it, the ski will either bog down or die. No biggy though, I just tap the gas a couple times and it's good for the rest of the ride.
    Sin City USA
    Quote Originally Posted by jfw432
    ...My ski hits incredibly hard at the bottom and is smooth all the way through the rpms. However, if I idle for more than 10-15 seconds without touching the gas and then nail it, the ski will either bog down or die...
    Lean! go 80 on the lo I think the 85 will be fat
    at 80 you should end up about 3/4 - 1 turn out, hopefully less than 1 turn
    Sep 2007
    In the water
    This is exactlywhat I intended for this thread. We all we gain from this one.
    Top Dog iceracer's Avatar
    May 2006
    wi
    I'm at 75 low with screw 1 1/2 out 165 high with screw 1 turn out ...factory head pipe with blaster limited ...ported small pin cylinder(low exhaust port timing) sxr carbs...pop off @ 22 psi...ski ripps!!!!water screws top 1 turn out and bottom 1/2 out...messed with screws and after 1 turn no more notice on bottom end!!!! engine is new so I haven't clamped the throttle but a little wide open in the bouys...I'll keep you posted
    Jul 2007
    GA
    Quote Originally Posted by iceracer
    You know, the guy that owned the ski before me had that exact same jetting and number of turns but it never ran right on the top end so I rebuilt the carb and could never make that jetting work again.
    Wish I could play with the screws in my pipe. I actually broke the allen wrench off in the screw...lol. I thought it turning... Haven't gotten around to getting the screw repair kit.
    Quote Originally Posted by JonnyX2
    Thanks for the advise JonnyX2. I will go ahead and order the 80 jet and see where it brings me.
    May 2006
    wi
    what carbs are you running...the sxr's are 40 mm I body mikuni's
    May 2006
    wi
    if your'e running a single 46...120 low and 150 or so high...works good
    Jul 2007
    GA
    Nah my carb is a single 40mm keihin.
