    PWCToday Guru LeeBotz's Avatar
    Aug 2003
    Brooklyn, New York
    Ultra 150 flame arrestor box
    Need a little advice. I am removing the stock flame arrestor box to installing tau ceti's. Now, i decided to install a primer kit as well. 2 questions...
    1. I removed the top part of the flame arrestor box, with no problem. Now I can't figure out how to remove the second part thats mounted on the carbs. I removed the wire bracket thats on the first and third carb and it still won't budge. I don't want to force it off and break something. Is there anything else that is holding it on the carbs?
    2. Which is the best way to install the primer kit with tau ceti's? I want to make it look as clean as possible.
    Thanks in Advanced!
    PWCToday Guru btldigger's Avatar
    Nov 2007
    Lebanon Tennessee
    Re: Ultra 150 flame arrestor box
    I wouldnt run the tauceti's without getting the carbs modded. It may cause you to lean out and burn a piston. To get the stock fa off take th 2 bolts out that hold the fa support bracket to the exhaust. Then pull up while rocking it back and forth. You can do this without taking the top off the fa.
    2004 ultra 150 71.3 @ mudbug IV 75.5 now
    http://www.ultra150.yuku.com/topic/364
    2000 ultra 150 work in progress 68.5 hunting 70
    http://www.ultra150.yuku.com/topic/2924
    1998 stx 1100
    1988 650sx
    Ultra 150 Mods
    http://www.ultra150.yuku.com/topic/2494
    Aug 2003
    Brooklyn, New York
    Yea, I had to remove the entire carb. Going to get it modded. Thanks!
    resident guru BBYamaha's Avatar
    May 2006
    San Antonio
    what do you mean carb mod, I got rid of the buck shot 50's and went back to stock but I still have the pipes and cant go with the stock arestor so I am gonna pick up some after market arestors...
    93 superjet 760 see engine build here...
    http://www.pwctoday.com/showthread.php?t=203959
    major overhaul in progress... again
    09 Superjet with goodies
