ModeratorPWCToday.com Is My Home Away From Home
Pump Removal & Impeller Change "Pics" Step by Step
Re: Pump Removal & Impeller Change "Pics" Step by Step
Thanks for posting that, and nice job with the photos. I have been thinking about going to a solas impeller.
resident guru
Your timing is impeccable! Make it a stinky, along with servicing the pump with new lube!
"Support OUR Troops"
2008 RXT-X255
81.2 mph @ 8660 rpm
VP WATER OPERATIONS, ALBEMARLE SOUND NC
2002 F12X, MACSBOOST #303, SOLAS 17/29, ECU PIRATE STICKER
YES.... Thanks, Plan on doing this very soon,
Land: 2000 Buell X1, with 1250 kit
Water: 2004 Honda R-12x Black/Silver
resident guru
Go for it. You'll wish you had done it a lot sooner. It's like a different ski.
Honda F12X (my favorite) Red of course
Used to have:
98 GP760, 97 GTX Sea Doo, 97 GP1200
Need to have:
F15X
Make sure you retrieve the rubber insert back out of your old impeller's shaft hole and install it into you new one or you'll have to disassemble it again to do it. It is hard to see inside the splined hole but it has to be there.
JR
'06 Pilot NAVI
3 '06 F12Xs
CR250
2 CR80s
1 XR100
2 PW50s
2 Vento Phantom 150s
'98 Allison Grandsport/Merc 2.5 SS
Jax. Fl.
"Confidence is the feeling you have before you fully understand the situation"
WHat do you torque the new impeller to?
- You may not post replies
- You may not edit your posts
Forum Rules
