Jet Ski Oil
What type of oil do you recommend to use for my 96 seadoo xp I just bought?
Re: Jet Ski Oil
Do a quick search and you will find you answer.
resident guru
Re: Jet Ski Oil
nice response! saved me the trouble lol
89 650 sx - lots of aftermarket! (Bobert540 old ski)
89 X-2 - new project
94 wr3 stock
Re: Jet Ski Oil
There are alot of different opinions on this subject, I used seadoo oil for the past few seasons with no problems. Many people say they use the cheap walmart stuff but since I do not have a grand sitting around to rebuild my engine because it blew due to lack of proper lubrication I go with the recommended oils. I am thinking about using Amsoil Interceptor, more expensive but a full synthetic and since I only mix 5-10 gallons of gas a week not too worried about the cost. The biggest thing is to use an oil that is API TC rated. There are so many opinions here you just have to do what you think is right.
Re: Jet Ski Oil
welcome to the forum. Folks are not usually so short answered around here, it is just that Oil is a highly debated topic lately and was just discussed to death on this thread (click on link below). With 38 posts, you have plenty to catch up on and I don't think we ever reached a unanimous conclusion.
http://www.pwctoday.com/showthread.p...&highlight=oil
I might also add to be sure and read the user guide (free download from www.sea-doo.com) before you attempt to start it. I have seen many a sad stories where a new owner does something that causes major damage. Like flooding the engine with hose water for example. Also, some other hot topics around here that you should be aware of is problems caused by bad fuel lines which is quite common if you still have the original OEM grey Tempo lines.
In general, stop riding your ski if it is not running right and fix the problem before it turns into a big expensive repair bill.
(2) 98 GSXLs
(1) 00 Challenger 2000
resident guru
Re: Jet Ski Oil
they need a sticky on just oil.
Re: Jet Ski Oil
I would never use cheap wal-mart / nappa / ect. oil..... read around... Bombardier is not needed like they would like you to think.
I would use the Amsoil value brand for stock ( it is cheaper than Bombardier oil) and for hi-po apps I would use their middle of the line, or what I use ..... Amsoil Dominator!!
Don't mix oils either.
And.... SDD is right, people are normally not so short around here. Good luck to you!
GROUP K PARTS FOR SALE-787 MOTOR
2008 RXP-X
2006 RXP
1996 GSX 1 SOLD 1 FOR SALE
XPLs and all parts are GONE!!
__________________________________________
I CAN CREDIT YOU MONEY IF YOU ARE BUYING OR SELLING REAL ESTATE, PM FOR INFO.
Re: Jet Ski Oil
Just use quality API-TC. I usually use the Sea-Doo oil, but if I can't get it I run to Wal-Mart and get the Synthetic Quicksilver API-TC. It's actually a little more expensive than the Sea-Doo stuff, but only one place around here sells the stuff and he ain't open alot.
Re: Jet Ski Oil
Blue Marble Oil. My 1987 650sx, 185 psi, wiseco, intake, carbon reeds, westcoast pipe, 93/105 octane mix (vp red) TONS of hours on it, ORIGINAL CRANK!!! Been
The trouble with real life is that there is no danger muisc...
Re: Jet Ski Oil
Any oil that is watercraft rated is good enough - tcw3
 Originally Posted by Ihop
I have been involved in the marine industry for 14 years and know more about jet ski's than 95% of the people here and can probably ride better than most too .
- You may not post replies
- You may not edit your posts
Forum Rules
