Results 11 to 18 of 18
    resident guru
    May 2005
    Crestview,FL
    Re: 97 gsx 951. How hard is it to replace stator?
    May 2007
    Peru, In
    Quote Originally Posted by Water Worx
    You dont have to remove the flywheel to replace the stator,the stator is on the front cover.
    Why do you need a new stator ??
    my bad!!!!!!!!
    May 2007
    Peru, In
    for some dumb reason i was thinking of a 717/787.. im incredibly sorry for the bad advice
    Quote Originally Posted by josh42575
    Not trying to bust your bubble but the 787 motor you dont have to remove the flywheel either,717 the stator is under the flywheel.
    PWCToday.com Is My Home Away From Home SeaDooSource's Avatar
    Sep 2006
    Ohio
    Sometimes if the stator gets grounded out it will fry the rectifier. Hopefully that didn't happen since that part is built into the mpem. If you find the rectifier is bad though, let me know since I've been working on a project to help with that without spending big $$ on a new mpem.
    OSD JetPump Rebuild Service here
    Heavy Duty RFI & DI Rectifier Upgrade here
    Everything you ever wanted to know about Mikuni carbs here
    Complete Single & Dual Carb Rebuild Kits with OEM Mikuni Parts here
    PWCToday Regular 97gsx951's Avatar
    Apr 2008
    eatonville
    yikes. well the shop i have it at says they have a new stator for 298 but i got a line up on one from a fellow in the classifieds for 120 shipped. They did the electrical testing and said for sure it was the stator. they have been pretty fair, i have only been charged a half hour to get it summerized from not being winterized and to diagnose the no charge problem. also they said only 2 hours to replace the stator. from what im hearing that is a good deal!!
    Apr 2008
    eatonville
    Quote Originally Posted by seadoodude
    then you must have the original white 591?
    2 hrs if you have a lot of experience working this motor and a shop buddy to clean all the parts that you remove. it is very tight working quarters. I would say 4-6 hrs. you will need to take it very carefully just to get the exhaust pipe back on with new gaskets and clean mating surfaces and precise torque sequences or it will leak water.
    but you have no choice, definately needs to be fixed and it is difficult to find a good shop that won't charge more then the skis is worth to fix.
    have you done any diagnostics with an ohm meter? In the shop manual there is a procedure. I went into some detail on this when I had a short in the stator. It is fairly common for metal shavings from the rotor to collect on the stator and short it out, in which case a good vacuuming will fix. could also be rectifier, which i think is part of the MPEM or simply a blown fuse or corroded wiring connectors.
    http://www.pwctoday.com/showthread.p...ghlight=stator
    591? or is that a typo for 951? i hope so cause it is white! is it a bad motor?
    PWCToday Guru Rconce01's Avatar
    Mar 2007
    miami
    Hey can you help me out, my stator was shorted out to ground and mechanically damaged, after replacing it my ski runs like crap on one piston. If you can shed some insight it's much appreciated! http://www.pwctoday.com/showthread.php?t=472195
