My 91 x2 Build
Page 1 of 6 123 ... LastLast
Results 1 to 10 of 58
Thread: My 91 x2 Build
    I dream skis Quik1's Avatar
    Aug 2005
    Vegas
    My 91 x2 Build
    Here we go, I previously started a thread for ideas on the smooth look. I started on the ski about a week ago. I will keep everybody posted as I go.
    I am going to make it look as sick as I can but don't have the money to build the big bore 750 yet, so I am just going to take all of the aftermarket 650 parts that I have and make the best 650 that I can. Dropping in a 750 later on will not be a problem. The body work in my opinion is the hardest part.
    Here are some of the pics from when I started.
    -Q
    My skis:
    91 X2, Build page: http://pwctoday.com/f100/my-91-x2-build-157285.html
    95 HX
    02 Sxi Pro
    JAN BREWER FOR PRESIDENT 2012
    Aug 2005
    Vegas
    Re: My 91 x2 Build
    Some more pics since I started.
    -Q
    My skis:
    95 HX
    02 Sxi Pro
    Resident Guru sah255's Avatar
    Apr 2006
    Mechanicsburg, PA
    Re: My 91 x2 Build
    Looks better already!
    Did you decide to build up both sides with 2 part foam?
    Were you able to separate the hood liner or did you have to cut and grind it all out?
    2010 Rickter
    2006 Superjet
    Frequent Poster kawashark's Avatar
    Sep 2007
    Fort Worth
    Re: My 91 x2 Build
    Keep the pics coming. What colors do you have in mind?
    92 Kawasaki X2: 750 Big Pin, Hotrods Crank, ProX Pistons, Dual 40 Keihins, Coffman Exhaust, Prok Arrestors
    93 Kawasaki 750sx: Stock
    Aug 2005
    Vegas
    Re: My 91 x2 Build
    Im going to try the foam, I have to glass some of the openings on the underside of the hood first, so I will probably start the foaming process in the next couple of days. I ended up just grinding the braces out because I looked at it for quite a while and decided to just grind or else I would have had alot more work. I would have had to rebuild all of the sealing surfaces. But the way that I did it is going to work out great for my air intakes, as soon as I get more done I will post some more pics. By the way, the paint that was on the ski was from the previous owner "HIDIOUS".
    -Q
    My skis:
    95 HX
    02 Sxi Pro
    I dream skis njrealtor55's Avatar
    Nov 2002
    Flemington, NJ
    Re: My 91 x2 Build
    i thought that paint job was cool - in a retro way.
    Jason
    PWC ADDICTION
    jason@pwcaddiction.com
    www.pwcaddiction.com
    CONTACT US FOR ROCK BOTTOM PRICES ON PWC PERFORMANCE PARTS & AMSOIL
    Aug 2005
    Vegas
    Re: My 91 x2 Build
    Kawashark, I actually was thinking about the color on the skis in your avatar. But not 100% sure yet.
    -Q
    My skis:
    95 HX
    02 Sxi Pro
    Aug 2005
    Vegas
    Re: My 91 x2 Build
    Started the fiberglass and put the first coat of foam on last night. I will post somemore pics tonight.
    -Q
    My skis:
    95 HX
    02 Sxi Pro
    Aug 2005
    Vegas
    Re: My 91 x2 Build
    Did the foam and sanded it down tonight. Cut some of the air holes also. I had to add somemore foam in some different spots that I saw after I cut most of it off and started sanding.
    -Q
    My skis:
    95 HX
    02 Sxi Pro
    Apr 2006
    Mechanicsburg, PA
    Re: My 91 x2 Build
    That's going to look sweet!
    What do you planning on using for material and how will you blend it into the existing surfaces?
    2010 Rickter
    2006 Superjet
