honda aquatrax turbo nightmare - Page 4
Results 31 to 40 of 40
  1. #31
    Apr 2004
    Alaska
    Re: honda aquatrax turbo nightmare
    Check the vacuum tubes. the shortest of the 2 has a very small brass orfice in it. Unplug it and see if its plugged by blowing through it, if it is not allowing air through take it out clean the orfice replace and should run fine. Mine did!
    Why winterize guys come , to Alaska and ride year round
    2) 02 F12X
  2. #32
    Feb 2009
    hudson,fl
    Hi. I have been told i have to replace my turbo on my aqua trax because a flap is not opening like its supposed to. they said rain water got inside there during the offseason and ruined it. any suggestions? Its a giant paper weight right now. ive only had it a couple years.
    brett
  3. #33
    Top Dog 99gp1200's Avatar
    Jan 2006
    United Socialist States of America
    If they are talking about the waste gate I think it could be freed up with some penetrating oil
    R-12X
    Manual Boost Control
    If you don't have to balance your watercraft its a boat
  4. #34
    Top Dog dav_dman's Avatar
    Dec 2001
    Louisville,KY/So.IN
    i'm in seminole 4-5 times a yr.. next time i go if you still have the issue you can bring it by we'll look at it. Send me your email address..mine is in my sig.
    lots of ski's over the yrs..
  5. #35
    Jun 2003
    JACKSONVILLE FL.
    Do a "search" on here for wastegate problems and you should find plenty of info on how to check/lubricate your wastegate.
    Honda Pilot NAVI
    F150 4x4
    3 '06 F12Xs
    CR250
    2 CR80s
    1 XR100
    2 PW50s
    1 Vento Phantom 150
    1 Honda SHI 150
    Jax. Fl.
  6. #36
    Mar 2012
    Louisiana
    Quote Originally Posted by JR IN JAX View Post
    I wish the owners would say what fixed their gear. Iím in a nearly same situation. Ski hauls *** then if you let off the throttle and hit it again it lags and never recovers performance
  7. #37
    Jun 2019
    North Carolina
    Quote Originally Posted by Dude269 View Post
    Did you ever figure out what it was?? Mine does that too and I was wondering if you got yours fixed
  8. #38
    Mar 2012
    Louisiana
    Quote Originally Posted by 03_honda_r12x_free4ever View Post
    I wish. I just installed Jimís boost system. I took it out and hit a crab pit float that broke both of my rear through hull nuts and almost sank. I plan on testing again this weekend. What have you done so far?
  9. #39
    Apr 2019
    Apex, NC
    Sounds to me like the Wastegate is getting stuck open. Where in NC are you? I've gotten to know these skis fairly well through fixing mine up (was bought broken) and tons of research.
  10. #40
    Mar 2012
    Louisiana
    Quote Originally Posted by Sethman919 View Post
    That would be any easy fix. I changed actuators twice and put a LVDT on mine to prove that the shaft is closing when off throttle. I also took it apart and cleaned the sealing surface of the waste gate there was no binding on the WG shaft either.
    Check your oil, if itís milky then you have a manifold leak. My oil is black and the exhaust side of the manifold is dry.
