Conversion ski- Conversion Pump? - Page 2
Page 2 of 45 FirstFirst 123412 ... LastLast
Results 11 to 20 of 447
    Mar 2005
    Santa Barbara, Ca.
    Re: Conversion ski- Conversion Pump?
    Quote Originally Posted by Laserman
    If he uses the bulkhead portion of the 650, along with the mounts for the pump, Then wouldn't the shaft line up properly until AFTER the bulkhead? I was referrring to the fact that the shaft "from that point forward" could be shortened.....no?
    Damn...I just chopped up two 650sx and two 550 hulls last week. I cound have cut some blocks and compared......Every time I throw something away, I end up wishing I had used it for something!
    Actually I just set both the 650SX pump and shaft along side the 550SX pump and shaft. Surprisingly both pump assemblies are nearly identical in length from the front of the intake cavity to the tip of the turning nozzle. The impeller seems to be set back the same distance as well.
    The 550SX shaft is 3.5" longer than the 650... so if I can get the 650 pump in the same centered location, the 550 shaft will work as is. Bearings and splines are the same. The other interesting thing is the steering nozzles have the same bore and it looks like the steering cable will line up as is.
    The 650 has mounting tabs kind of on an angle and the 550 seems parallel to the pump shaft. Looks like the 650 pump is about 7/8" bigger in diameter than the 550 and will need to set about 3/4" higher to center,,, which means the tray floor will have to raise.
    Will try and get Pics as I go...
    PWCToday.com Is My Home Away From Home BlueBreadTruck's Avatar
    May 2006
    Cape Cod, MA
    great job man....get tons of pics
    86' Kawasaki X-2 800cc
    Sm pin 750 at 83mm, 40mm bored SXR carbs, FPP B pipe with Blaster chamber, Skat 14/19 Swirl
    89' Kawasaki X-2 1100
    ZXI 1100 triple, 96' carbs, OP f/a's, Skat 16/22 C-75 Swirl
    95' Yamaha Waveblaster 1
    Reliable stock backup ski
    PWCToday.com Is My Home Away From Home Laserman's Avatar
    Apr 2006
    Orlando, FL 32817
    now THIS is exciting stuff!
    1985 JS 550/750 Stand-up: http://www.pwctoday.com/f72/smileys-...50-114680.html
    1984 JS550 TYPHOON 750 conversion: http://www.pwctoday.com/f72/laserman...ct-186297.html
    1992 Sport Cruiser "Sportscar" Conversion: http://www.pwctoday.com/f72/laserman...-a-173049.html
    Here's a helpfull thread on 550\650 conversions: http://www.pwctoday.com/f72/just-ano...on-133898.html
    Feb 2006
    Edmonton
    Lots of pics
    PLEASE !!!
    Mar 2005
    Santa Barbara, Ca.
    Got a lot of measuring done today... looks like the engine and driveshaft support bearing are going to have to be raised about 1/2" to center with the larger diameter pump. To keep the bottom all aligned, the pump center has to move up... but I think that can be done with the engine adapter plate.
    Looks like the pump and cavity will fit... the center runner on the 650 is a bit wider than on the 550 and I am trying to decide how and where to blend them.
    Hope to start cutting tomorrow.
    I am surprised how similar the the bottom shapes are. Took lots of pics and will post when I get on the other computer.
    I guess I should move this to Personal Builds but it seems there is a lot of interest here on Vintage,,,what do you think?
    Apr 2006
    Orlando, FL 32817
    Well, you haven't posted any pics yet, so maybe you should start a build thread.
    No matter where you post, WE WILL FIND YOU!
    Your idea has been tossed around here for awhile - there are alot of members interested in this.
    LOTS OF PICS!
    Besides, build threads are nice - I have one thats on it's third hull
    I dream skis seymore's Avatar
    Jul 2006
    Lake Havasu
    [quote=Laserman]Well, you haven't posted any pics yet, so maybe you should start a build thread.
    I know where he lives!! LOL !!
    Mar 2005
    Santa Barbara, Ca.
    Pictures tomorrow...I am cutting right now!
    Mar 2005
    Santa Barbara, Ca.
    OK... here are some pics... pump comparisons, note 3 1/2" longer drive shaft on 550SX. The current plan is to splice the whole 650 pump cavity into the 550. Runner down the center is a little wider than the 550. Flutes are very close. Overall lenght is the same.
    Mar 2005
    Santa Barbara, Ca.
    Here is a shot of the 650 insert without all the foam...You can see the steering cable tube which I will need to replace. I will also a add bigger water line and rear exhaust before I re-foam everything...
