More problems with Factory Mod Pipe on Blaster...
    PWCToday Newbie stabaan's Avatar
    Jul 2007
    SA
    Just finished the install and ran the ski with the flush kit, water is leaking out of the manifold near one of the bolts.
    Any ideas?
    Thanks
    2005 SXR
    96 B1
    PWCToday.com Is My Home Away From Home bad93blaster's Avatar
    Jan 2005
    billerica mass
    Re: More problems with Factory Mod Pipe on Blaster...
    gasket or tighten the bolts
    there is no fun playing stock
    Pull the manifold off & reseal it.
    Its not rocket science.
    Jul 2007
    SA
    It's strange though, gasket is brand new and bolts are torqued to 30NM as specified.
    2005 SXR
    96 B1
    PWCToday.com Is My Home Away From Home MikePeavler's Avatar
    Elwood, Indiana
    Flip you gasket upside down and put some carmex lip suff on both sides of it when installing.
    Mike
    Fixin' To Get Slapped PWCToday.com Is My Home Away From Home skraggy's Avatar
    May 2005
    St.Pete FL
    Check both gasket surfaces for straightness with a straight edge.
    Retired...
    Jun 2007
    Myrtle Beach, SC
    I personally love the permatex copper in the spray can.... use it!
    Squarenose superjet with a little get up
    Jetworks bigbore, dual 46mm Blackjacks, MSD TL, 205 compression, B pipe mod w/ ECWI, 12/17 Skat Swirl
