F-12 Getting Water in Oil
Results 1 to 10 of 13
    Dec 2005
    Chapin, SC
    What is the most llikely cause of getting water in the engine oil? Ski runs great but oil starts to turn milky after a couple of hours run time.
    Resident Guru J-Rod's Avatar
    May 2007
    Kingwood, TX (Houston)
    Re: F-12 Getting Water in Oil
    Little more info is needed. Has it been upside down for amount of time? Has it been cold where you are at i.e. water freezing in motor??????
    More info please.
    Jarrod
    Dec 2005
    Chapin, SC
    The unit has never been underwater nor in freezing conditions. It blew a cylinder big time several months ago and was repaired by local Honda dealer but I only recently have ridden it enough to discover the problem. Honda isn't offering any help.
    Jul 2007
    Chesapeake Beach, MD
    sounds like the dealer messed up, id say its a headgasket. Take it back to them and have them repair it.
    2008 RXP-X. R&D Intake Grate/Riva FF Exhaust/4 inch intake/83mm nozzle. Mine
    2007 RXP. Riva Washers, otherwise stock. Hers
    Top Dog Taquin's Avatar
    Jun 2003
    St. Louis, MO
    Or the oil cooler o-rings....
    Honda F-12x 2002 - Solas intake grate - SuperJim modified rideplate - R&D sponsons - Solas impeller - Livorsi boost guage and depth finder - HydroBubble anchor with custom mounts - rear pop up cleat - front cleats - powered ventalation fans - K&N air filter
    Jul 2007
    Quote Originally Posted by Taquin
    i didnt even know our skis had oil coolers on them. Shows how much I know. Reason I said headgasket is because chances are if you has any cylinder work done then the head was removed for maintenance.
    Banned
    Feb 2006
    Camden N.C.
    Could be a bad turbo too, I sold one to a guy in cali and he said the turbo was letting water in to the oil, I doubt water and oil is mixing from head gasket, if it was blown that bad it wouldent run good, the water jackets go all the way around the cylinder so Id say water would go in to cylinders too causing it to hydro lock and all kinds of other stuff would be happening. Head gasket is possable tho...... do a compression test, leakdown
    Banned
    Feb 2006
    Camden N.C.
    Oh this is non turbo,hummmm
    Top Dog spatera's Avatar
    Jul 2006
    South Ga
    You said the dealer has been into the motor before. I'm by no means an expert but after taking mine apart I'd agree with Taquin. Looking at my o-rings I wouldn't reuse them. The ones on the oil cooler were just about flat.
    07 Honda F12X Saphire Blue
    MacBoost, Large intercooler, solas intake grate and impeller.
    03 Honda F12X Red
    05 SeaDoo GTX 4-tec Supercharged
    Used to have:
    98 GP760, 97 GTX Sea Doo, 97 GP1200, 02 Honda F12X, 2-03 Honda F12X,
    Need to have:
    F15X
    Jan 2006
    Florida
    I like that orange grease on the sensor in the second picture.
