Factory Mod Pipe on Blaster - Help!
Results 1 to 10 of 16
    PWCToday Newbie stabaan's Avatar
    Jul 2007
    SA
    I'm in the process of installing a blaster factory mod pipe on my stock blaster and can't get the head pipe to line up with the manifold.....HELP!!!
    Also, the stock blaster head has a thin pipe connecting to the stock exhaust chamber, what is that and where does it go on the new pipe?
    Help much appreciated!
    Thank
    2005 SXR
    96 B1
    PWCToday.com Is My Home Away From Home MikePeavler's Avatar
    Mar 2005
    Elwood, Indiana
    Re: Factory Mod Pipe on Blaster - Help!
    1. You plug the 1/8 line coming off the stock head.
    2. As far as the "head pipe"....are you talking about the part with the curve that has 3 bolts going into the mainfold?
    I just need to make sure your talking about the right part. Also don't forget to add dual cooling if you ride it hard. Where are you located and what have you done with the jetting?
    Mike
    Jul 2007
    SA
    Yes, the head pipe with the 3 bolts going into the manifold. Any ideas?
    As far as jetting goes I'm changing the stock jetting (single carb) to 145 main and 120 pilot per FP recommendation.
    Dual cooling, interesting. I was thinking of putting a restricter in to improve bottom end. Motor is 100% stock apart from a flame arrestor.
    Thanks again.
    2005 SXR
    96 B1
    Mar 2005
    Elwood, Indiana
    Yeah....are you trying to hook it up with the other hoses and the camber attached? If so...forget about it...take the chamber off and then put the head pipe on ..then the chamber. You MAY have to grind the the hull a tad if it rubs. The blaster hulls are hand build which left a little imperfections on some..."mine never had any" but some have had to. The main thing is aligning up the chamber properly to the waterbox. this takes time and careful cutting on the hoses
    M
    Jul 2007
    SA
    Yup, I'm following the instructions word for word so am trying to instll the head pipe on it's own. I ground the hull away today as much as I possibly could and the thing still won't fit. See pictures at..
    http://web.mac.com/stabaan/iWeb/Site...%20Issues.html
    2005 SXR
    96 B1
    Mar 2005
    Elwood, Indiana
    Ouch...I've never had to go that deep into the hull. Ive built at least 10-12 blasters over the last 2 years and none were that far off. Have you had the engine out and or mounts removed for any reason? Does the coupler on the PTO shaft line up perfect?
    M
    Jul 2007
    SA
    It was rebuilt just before I got it and runs perfect so I'm sure that the coupler's lined up right...I'm lost....
    2005 SXR
    96 B1
    Feb 2005
    ive installed this setup on quite a few blasters and none have hit the hull.
    What are you using for engine shims there ? thickness ?
    Usually there is only a mm or so gap between the hull and the header pipe so the angle you go in at is pretty important.
    Also make sure that your botom water barb on the header pipe and the worm drive from your clamp are not hitting the hull.
    Jul 2007
    SA
    Please can you expand on the difference the shims would make? I assume that any change to their thickness would affect alignment?
    As for the clamp and barb I'm sure they aren't the problem.
    Thanks for all the advise!
    2005 SXR
    96 B1
    Jul 2007
    SA
    Fitty-Pee, yoiu never gonna believe this! Worm drive was pressing against the manifold, not the hull...How stupid am I?!?! Now I have to get the fiber glass out!
    Thanks for your help!!
    2005 SXR
    96 B1
