Page 17 of 18 FirstFirst ... 715161718 LastLast
Results 161 to 170 of 175
  1. #161
    Top Dog orangefinger's Avatar
    May 2006
    Reno,NV
    Re: super chicken appreciation thread
    quick update rhaas parts arrived , quick fitment test prior to drilling final holes in plates for motormounts....next step shortening driveshaft....
    then fitment of short block ( goal only need lower bulge in firewall ) , then working on exhaust/carb-flame arrestor bulge...IMG_2068.JPGIMG_2071.JPGIMG_2073.JPG
    94 Blaster "KAW 1100cc"
    650 SC
  2. #162
    Jan 2018
    FL
    Quote Originally Posted by zpilot View Post
    Cometic has the measurments and will make a gasket any thickness for $15.
    Sorry, but did you ever test the ski with the pjs setup?
    No I bought the SC a month ago and it was really rough .
    i put it Appart . It has this engine below in it then I bought the PjS online and received it a week ago , sellers told me it was Silas 15/20
    he also says it should work with factory pump and nozzle , what do you think ?
    Matt
  3. #163
    Resident Guru zpilot's Avatar
    Jun 2007
    Los Angeles
    Quote Originally Posted by orangefinger View Post
    Do you/we know of any other Kawi drive shafts that might work for this application?
    Mav,
    Not sure, I have a mag pump and 10/18 big hub swirl and it works really well but looking into a new option as we speak for a bit more RPM and speed on top.
    I'd be interested in speaking with the seller if possible. I'll PM you.
    1995 Kawasaki SC
    PJS Viper 9000 800cc
    PJS Exhaust Manifold
    Coffmans Full Exhaust
    Custom Jetinetics Flywheel/drilled ring gear
    12 Vein SS Magnum Pump
    10/18 Skat Track Swirl Impeller
    PJS Rip Turn
    DG Intake Grate
    1994 Kawasaki XIR
    Group K Head Mod
    PJS Exhaust
    Skat 9/17 Big Hub Swirl
    UMI Bars
  4. #164
    May 2006
    Reno,NV
    I am cutting the 900 ZXI shaft back , u cant use the oem SC shaft otherwise the threads for coupler end up where the shaft hole is
    650 SC
  5. #165
    Jun 2007
    Los Angeles
    I assumed you where shortening it on the spline end. Makes sense.
    1995 Kawasaki SC
    PJS Rip Turn
    DG Intake Grate
    1994 Kawasaki XIR
    Group K Head Mod
    PJS Exhaust
    UMI Bars
  6. #166
    May 2006
    Reno,NV
    I might have too depends on who can do what ......the spline end on the 900 shaft are longer than on the 650
    650 SC
  7. #167
    PWCToday Newbie FlyerTaz's Avatar
    Dec 2017
    Tennessee
    Solas 13/18. Or. Skat Trak 4/7 ?
    Which is better with 6 vane pump? I'd like more bottom end for pulling tubes and skiers.IMG_1717.JPGIMG_1717.JPG
  8. #168
    I dream skis sportsfreak29's Avatar
    Oct 2011
    Midland, Tx.
    Skat on a Kawi.
    Ski situation in limbo!
    Special thanks to Chris Newmiller, and Mitchell at M&M Marine!
  9. #169
    PWCToday Guru 123hi's Avatar
    Jul 2014
    NorCal
    Sweet! I always thought this would be a cool build to do. I’m excited to see how it turns out and how it feels in the water. I have an SC hull sitting around - this is making me want to pull it out & clean it up. Keep up the good work!
  10. #170
    Jul 2014
    NorCal
    My 92 awaiting a full rebuild...
