Results 1 to 10 of 13
    PWCToday Regular picturethis's Avatar
    May 2004
    motor city
    Running a Seadoo Without a Hose On-land
    How Long Can the 800 motor run out of the water without a hose attached safely
    Re: Running a Seadoo Without a Hose On-land
    About a minute,the exhaust heats up quickly.
    Get your Fat Dudes T-shirts right here PM me for details !
    Jan 2004
    Atlanta, GA
    Manual will say 15 seconds... 1 minute is probably OK, but longer than I would run it.
    Current:
    2003 Kawasaki SX-R 800 with FP wet pipe
    2006 Sea-Doo RXP (stock)
    2006 Sea-Doo RXP (minor mods)
    Past:
    2000 Yamaha GP1200R
    2004 Honda R-12X with Macboost stage 2
    May 2005
    Right here
    Just try it, and let us know the results.
    I dream skis fushion3's Avatar
    Oct 2006
    Florida
    Do yourself a favor,
    Follow what ever the manual say's because it will cost you bucks in the long run. The motor will be fine in the 15 seconds, its the carbon seal that will heat up so fast without water around it to cool it in about 10 seconds and it gets hot enough to burn your fingers if you touch it, I talking from experience here that's why I changed to the old fashion bearing coupler style seal to run mine out of water... good luck.
    Let me know which one of you guys is winterizing while running on the hose or is only fogging for 15 seconds.How long you can run it with no water also depends on the air temp,you can run one much longer in cold weather than in warm weather,just for the record I haven't smoked a carbon ring yet and I work on these every day.
    Quote Originally Posted by fushion3
    Reach down & touch the bearing carrier after running it on the hose for a couple of minutes....
    Top Dog
    Nov 2006
    Twin Lakes ID
    By "carbon seal" you're talking about the seal where the impeller shaft exits the hull, correct?
    Jan 2004
    Atlanta, GA
    I think the carbon ring is good for 5 minutes before it's temps become a concern.
    Current:
    Past:
    2000 Yamaha GP1200R
    Top Dog pdxrealtor's Avatar
    PDX - Oregon
    When run on the hose, the carbon seal does not get any water cooling benefit and it will heat up, but not in 15 seconds.
    I always take a pitcher if I am going to run for more than a minute or two on the hose and dump cold water on the carbon ring to cool it off. I usually only need to this while winterizing, or if I am trying to figure what the heck I did wrong while putting somthing back together
    GROUP K PARTS FOR SALE-787 MOTOR
    2008 RXP-X
    2006 RXP
    1996 GSX 1 SOLD 1 FOR SALE
    XPLs and all parts are GONE!!
    __________________________________________
    I CAN CREDIT YOU MONEY IF YOU ARE BUYING OR SELLING REAL ESTATE, PM FOR INFO.
