    Top Dog Landworks's Avatar
    Mar 2007
    MA
    Can i throw my seadoo cover in the washing machine?
    then just air dry it? Or will i ruin it? thanks
    Re: Can i throw my seadoo cover in the washing machine?
    Yes just use the gentle setting,I wash them all the time.
    Mar 2007
    MA
    awesome, thanks!!!
    PWCToday Regular wes's Avatar
    Oct 2007
    Chicago
    Get a botle of 303 High Tech Fabric Guard™ for after wash treatment.
    If your boat cover is suitable in size for a washing machine, these steps should be followed:
    1. Use only natural soaps. No detergent.
    2. Wash and rinse in cold water.
    3. Air dry. Never put Sunbrella fabrics in your dryer.
    As part of the finishing process, Sunbrella fabrics are treated with a fluorocarbon finish, which enhances water repellency. This finish is designed to last for several years, but must be replenished after a thorough cleaning. Use a 303 High Tech Fabric Guard™ as the preferred re-treatment product for Sunbrella fabrics. Fabrics should be retreated after thorough cleaning or after five years of use. Check with your local Sunbrella dealer or distributor for more information.
    303 should be applied to Sunbrella fabrics after each thorough cleaning, which typically removes the original fluorocarbon finish and reduces the fabric's water resistance. After cleaning the fabric, allow it to air dry completely and then apply 303 in a thin, even coat. After allowing the first coat of 303 to air dry, apply a second thin, even coating of 303. Two light coatings are more effective in restoring fabric water resistance than a single heavy coating. The 15-ounce aerosol provides coverage of up to 50 square feet of lightweight fabric.
