I'm thinking about buying this jet ski. Its a 95 seadoo Bombardier, its been sitting for 4-5 yrs & was not winterized before it was parked. The owner tells me that the pick up does not work ( not sure what that is) but he says its not that big of deal & a hose at the impeller sometimes comes off & you need to put it back on. What kind of problems did these machines have & is it worth me trying to get it for around $700.00 - $1000.00 , I'm not sure on the model forgot to ask him when i talked to him but He says its around a size 900. & yes it did run before he parked it , any Help would be greatly appreciated.
95 Seadoo Bombardier Question
Collapse
X
Re: 95 Seadoo Bombardier Question
If you do not hear it run and it is not a 1995 XP 800. It is worth about $200.00 without even knowing for sure what may be wrong with it.
A perfect 1995 SP, SPX, GT is only worth about $1500.00.email Chris at Watercraft Magic [email protected]
95XP is the only 95 model with the 787 engine.Y'all know me, still the same O.G. but I been low-keyhated on by most these &^$$@s with no cheese, no deals and no G's, no wheels and no keys, no boats, no snowmobiles, and no skis, mad at me cause I can finally afford to provide my family with groceries
WWSRD , What would Speed Racer do ?
Not winterized, eh? Sitting for 4-5 years like that, huh? Stuff was wrong with it BEFORE it sat ignored and unwinterized for 4-5 years, you say? And you're in PA, at least some parts of which get a little cold in the winter?
This sounds like a nightmare project ski. Be very, very cautious. Take someone with you that knows Seadoos.1996 XP (787 engine)
1997 GSX (787 engine)
Mostly factory stock
When I go tomorrow to look at it again, I'll look at the plugs to see which way they angle. I'll also get the engine # & go from there. Would it be ok to take a good battery, clean the plugs & shoot a shot of starting fluid in the air breather to see if it starts or wouldn't you guys recommend it?
Originally posted by cbr600rrWhen I go tomorrow to look at it again, I'll look at the plugs to see which way they angle. I'll also get the engine # & go from there. Would it be ok to take a good battery, clean the plugs & shoot a shot of starting fluid in the air breather to see if it starts or wouldn't you guys recommend it?----------------------------------------------------
1996 XP
2007 GTXL
First thing to do is remove the sparkplugs and the grey driveshaft cover and see if you can spin the motor with your hands. If not, do not bother installing the battery.
The engine ID tag for a 718 motor is on the top of the magneto housing.
For a 787, it is on the back of the motor by the pipe side motor mount.Last edited by Watercraft Magic; 10-03-2007, 02:36 PM.email Chris at Watercraft Magic [email protected]
